Dazed Dreamer Posted November 30, 2005 Share Posted November 30, 2005 first of all thank you so much Imdew for this engine, but I am having problems with getting it in place with the transmission the 2 bottom screws wont go in all the way the go all the way then stop about half an inch can somone give me some pointers for an easy way to get this engine in? last time I did this it took less than 30 minutes but today I was working on it for 5 hrs with no luck PLEASE HELP Quote Link to comment Share on other sites More sharing options...
ShawnW Posted November 30, 2005 Share Posted November 30, 2005 Make sure you arent hitting the motor mount studs on the crossmember and that you have the transmission jacked up a little bit. You may also have a metal splash plate on the bottom of your engine that is bent causing the engine to not slide on all the way. Quote Link to comment Share on other sites More sharing options...
Dazed Dreamer Posted November 30, 2005 Author Share Posted November 30, 2005 Make sure you arent hitting the motor mount studs on the crossmember and that you have the transmission jacked up a little bit. You may also have a metal splash plate on the bottom of your engine that is bent causing the engine to not slide on all the way. the motor mounts studs are fitting fine into the crossmember i have my transmission jacked up atlease 5 inches floating oabove the crossmember and I remove the splash guard so it would be easier to fit it Quote Link to comment Share on other sites More sharing options...
svxpert Posted November 30, 2005 Share Posted November 30, 2005 you have to turn the crankshaft to get the clutch/torque converter to seat. Quote Link to comment Share on other sites More sharing options...
Dazed Dreamer Posted November 30, 2005 Author Share Posted November 30, 2005 you have to turn the crankshaft to get the clutch/torque converter to seat. yah the gears are fit in fine maybe I just have to jack the transmission higher or something Quote Link to comment Share on other sites More sharing options...
DerFahrer Posted November 30, 2005 Share Posted November 30, 2005 Manual or auto? If it's a manual, you know that little shiny metal snout that sticks out of the input shaft? That has to slide into the pilot bearing in the flywheel. If you don't have it lined up enough, that snout will just hit the pilot bearing instead of sliding into it. Quote Link to comment Share on other sites More sharing options...
Dazed Dreamer Posted November 30, 2005 Author Share Posted November 30, 2005 Manual or auto? If it's a manual, you know that little shiny metal snout that sticks out of the input shaft? That has to slide into the pilot bearing in the flywheel. If you don't have it lined up enough, that snout will just hit the pilot bearing instead of sliding into it. that wasnt the problem but all of a sudden it slid into place thismorning but now I have a bigger problem the harness cant hook up to the engine is there an adapter piece or am I gonna have to get a new computer and harness? Quote Link to comment Share on other sites More sharing options...
lmdew Posted December 1, 2005 Share Posted December 1, 2005 you should be able to swap the harness over from your old engine without to much trouble. For the wires that go under the manifold, tie a string to the plug when you pull it back and then you can pull the new one back under. Quote Link to comment Share on other sites More sharing options...
