kingbobdole Posted November 30, 2005 Share Posted November 30, 2005 .....Move. Get in my wagon this morning, try to back it down the drive, shift it into reverse(but it might be in 4th hard to tell) and release the clutch.... car stalls.... Try to get it out of gear... shifter wont move at all... so I restart, rev the ************ out of it, dump the clutch... stall... restart, shove into LO rev it up dump clutch, stall. Hill holder cable is in one piece, tried pounding on the shifter linkage from under the wagon with a hammer, wont budge... I cannot get it out of gear... or to even move down the drive with the clutch in.... I drove it around last night and parked it here... Whats going on!?! Link to comment Share on other sites More sharing options...
NVBigBlue Posted December 1, 2005 Share Posted December 1, 2005 Any chance you might have a build up of ice somewhere? Guess I could have clarified.... Any chance that you might have gotten what inside the gearbox? I had that happen on an old chevy 4x4 one time out hunting. Made a river crossing no problem, but the breather hose was cracked and it let water into the trans. Froze during the night. Finally let loose when it started warming up during the day. Link to comment Share on other sites More sharing options...
zyewdall Posted December 1, 2005 Share Posted December 1, 2005 Hmmm. I had my hill holder misadjusted, so it never released once after I pulled into a parking space. Locked the wheels so bad that it couldn't even budge in four low 1st gear. But that doesn't really address why it's stuck in reverse/4th. Dunno... Link to comment Share on other sites More sharing options...
Cougar Posted December 1, 2005 Share Posted December 1, 2005 It sounds like something is locking up the wheels. Link to comment Share on other sites More sharing options...
DrKrazy Posted December 1, 2005 Share Posted December 1, 2005 Emergency Brake locked up/didn't release somehow? Sounds like a fun problem Phil! Link to comment Share on other sites More sharing options...
joostvdw Posted December 1, 2005 Share Posted December 1, 2005 Do you have pushbutton 4WD? because you can lock a pb 4WD by driving it on the streets in reverse, I've seen it happen. maybe you can fix it by jacking up the front/rear and see wich wheel locks? good luck, Joost Link to comment Share on other sites More sharing options...
kingbobdole Posted December 1, 2005 Author Share Posted December 1, 2005 Ok... As far as the ise thing, I dount it, I haven't made any river crossing recently, I DID change the gear oil earlier this year and it wasn't cold enough for frost let alone ice.... The tranny is a D/R not a PB... thats how I got it into Lo:rolleyes: I havent been driving around in 4wd either, its been dry here. I doubt its the wheels locked or the brakes... I know it doesnt move and if that was the only issue I might heavily suspect that, but my HUGE problem is that its stuck in gear... My 2 big Ideas right now are this: Noss Idea: Broken shift fork jammed in the gears... He had this happen to a Civic he beat the hell out of:grin:. His solution is new tranny Simmions(old auto guy) ideea: The tranny "misgated" due to old bushings and actually got stuck between 4th and reverse.... His solution is to get to the real shift linkages in the tranny and knock some sence into it. Any thoughts on that? Link to comment Share on other sites More sharing options...
jeffast Posted December 2, 2005 Share Posted December 2, 2005 this wouldn't have been yesterday after noon would it? Link to comment Share on other sites More sharing options...
BlueSteel Posted December 2, 2005 Share Posted December 2, 2005 i had the same sorta problem (ish) when stopping in 4th gear to get it back out of 4th i had to rev it right up and ease the clutch so the car start to go forwards while pulling back on the gear leaver till it popped out then put it back to first or reverse or whatever and drive off Link to comment Share on other sites More sharing options...
spanky_pete Posted December 2, 2005 Share Posted December 2, 2005 My hatch does that sometimes when it sits outside for a few days of inclement weather. The clutch gets wet and the pressure plate sticks. Usually it goes away after things dry out. Link to comment Share on other sites More sharing options...
zyewdall Posted December 2, 2005 Share Posted December 2, 2005 kingbobdole said: Simmions(old auto guy) idea: The tranny "misgated" due to old bushings and actually got stuck between 4th and reverse.... His solution is to get to the real shift linkages in the tranny and knock some sence into it. Any thoughts on that? Hmmm. Maybe. My truck doesn't have any line up pins for the shifters (transmission from a '86 truck, when the line up pins were in the shift tower, and shift tower from a '84, when the line up pins were in the transmission). You can find all kinds of places in between actual gears that don't do anything. Fun one is right next to first, thats actually still in nuetral. I'm used to it now and don't even notice the absence of em but even when I was learning it, I never had it get stuck anywhere. It could happen though I guess if bushings were worn enough.... Also check the obvious -- my dad had a pair of sunglasses fall from the dash onto the shift lever area of his outback, and keep the lever from moving forward into 5th any more. He thought the tranny had suddenly lost 5th, till he turned the light on and saw the sunglasses sitting there.... Zeke Link to comment Share on other sites More sharing options...
kingbobdole Posted December 2, 2005 Author Share Posted December 2, 2005 anyone have a link to a pic of a tear down of a D/R? or can you tell me if I take the back plate off can I get to the internal linkages? Link to comment Share on other sites More sharing options...
TurboXT Posted December 2, 2005 Share Posted December 2, 2005 Phil, you are crazy............. Just had to say that. Something is binding (duH!) and it sounds strange, and I wouldn't pull it apart yet. There is such a thing as over-troubleshooting, making the problem worse than it is. I remember you having an issue with the front wheels locking up when you first got the wagon, and I suspect foul play yet again...and yes, it is cold enough to freeze outside, I have the ice to prove it! What you need to do is.....tie a tow rope onto Noss's SHO, and pull it down the driveway, get it onto a level surface.....then see if the problem goes away. I suspect a Hill-holder issue, and I know you looked at it, but hill holders suck royal A$$..... Or I guess you could put the D/R lever in neutral, and let it roll down. UNLESS....you bent something off roading, or your tranny is blown...like Jeff's 6. He he Rick Link to comment Share on other sites More sharing options...
kingbobdole Posted December 2, 2005 Author Share Posted December 2, 2005 Fixed it... kinda Broken Wagon+Phil+ Rage= Fixed wagon... I basically just rocked the $41t out of it then while rocking beat up the shifter.... That'll teach it! Link to comment Share on other sites More sharing options...
operose Posted December 2, 2005 Share Posted December 2, 2005 kingbobdole said: Fixed it... kindaBroken Wagon+Phil+ Rage= Fixed wagon... I basically just rocked the $41t out of it then while rocking beat up the shifter.... That'll teach it! YEAH YOU SHOW THAT WAGON WHO'S BOSS! (score one for humans) Link to comment Share on other sites More sharing options...
