SUBARU3 Posted December 1, 2005 Share Posted December 1, 2005 My 5 speed manual FWD 1995 Impreza has this squeak, more so when cold. Comes from what appears to be the rubber trans mount. Is this common????? Has any one else experienced this? When I take torque loads on and off the trans, like when clutching, it makes this noise. It's not mechanical and the car only has 63k on it. Should I just replace the mount? Thanks much, Todd Link to comment Share on other sites More sharing options...
Legacy777 Posted December 2, 2005 Share Posted December 2, 2005 Are you sure it's coming from the mount area under the car? Link to comment Share on other sites More sharing options...
SUBARU3 Posted December 2, 2005 Author Share Posted December 2, 2005 Pretty sure.....it's tied to engine torque. Very noticeable in winter and right after you start moving cold. Nothing after warm up and nothing ever in Texas summer! Only winter. I drive low miles on this car. Squeaks when I let on and off the gas. Todd Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted December 2, 2005 Share Posted December 2, 2005 Could it be your clutch T/O bearing?I think you trans mount would make this noise all the time if it needed to be replaced. Link to comment Share on other sites More sharing options...
SUBARU3 Posted December 2, 2005 Author Share Posted December 2, 2005 Could it be your clutch T/O bearing?I think you trans mount would make this noise all the time if it needed to be replaced. No...no noise when clutch depressed or released while sitting still. It's only when you add "load or torque/twist" during movement. And never a noise in the hot summer, only when the car is cold and only till it gets warmed up. It completely temp related. Maybe the mount is loose and as it heats up it expands tight enough to stop the noise? (I will check it again) Todd Link to comment Share on other sites More sharing options...
