feef Posted December 2, 2005 Share Posted December 2, 2005 I own a 95 legacy wagon; I am interested to know the process of finding and replacing my dimmer switch. I believe that I have fried it in the process of installing my aftermarket stereo. If anyone has some info on this at all it would greatly assist my endeavor. Link to comment Share on other sites More sharing options...
Gnuman Posted December 2, 2005 Share Posted December 2, 2005 you mean the one on the stalk where you turn on the lights? Link to comment Share on other sites More sharing options...
feef Posted December 2, 2005 Author Share Posted December 2, 2005 I am not sure, a machanic told me that there is a switch mounted inside the dash as well? Link to comment Share on other sites More sharing options...
Cougar Posted December 2, 2005 Share Posted December 2, 2005 I think the dimmer you are talking about is for the dash lights, correct? It should be mounted on the dash, left of the steering column. What makes you think the dimmeris bad? Are the dash lights out? I would suspect a fuse is blown if that is the case. I doubt the dimmer is bad. Link to comment Share on other sites More sharing options...
nipper Posted December 2, 2005 Share Posted December 2, 2005 dimmer is just a rheostat. If you fried that you would know it bigtime, would envolve at the very least a funny smell, maybe a little smoke... check the fuses Link to comment Share on other sites More sharing options...
feef Posted December 2, 2005 Author Share Posted December 2, 2005 All the fuses that blew I have replaced and still no dash illumination. Actually it's strange the dash illumination only works when the headlights are off, as soon as I turn them on I lose illume. There was a smell of burning plastic, so that is why I assumed I fried my switch. Do you know how to locate the rheostat? and assess it. Link to comment Share on other sites More sharing options...
avk Posted December 3, 2005 Share Posted December 3, 2005 The box you're looking for is called illumination control unit. I don't know where it is on a Legacy. The variable resistor in the stalk changes its input voltage and the unit controls current in the main circuit. It sits on the ground side of it. I'd suggest checking both input and output voltages with a meter while moving the adjusting knob, then you'll know which component is bad. Link to comment Share on other sites More sharing options...
