dolehendrix Posted December 2, 2005 Share Posted December 2, 2005 AS STUPID AS THIS WILL SOUND.... 95 legacy 2.2 awd/auto once again related to a transmission swap i did, a friend removed the tb/vacuum lines. i have them all back on, except for the one that goes from the intake manifold to the intake bellows (filter to tb). i need a picture of this hose since it has gone missing, i need to show him what it looks like so he can tell me where he put it.... -thanks again Link to comment Share on other sites More sharing options...
dolehendrix Posted December 4, 2005 Author Share Posted December 4, 2005 bump? any vaccuum hose diagrams? i could be wrong, but if it helps, this is the hose with the right angle fittings on it. i'm away from the car until next week, when i need to get it running-- so id like to figure this out before then Link to comment Share on other sites More sharing options...
ShawnW Posted December 4, 2005 Share Posted December 4, 2005 Take the whole assembly off the car and it gets really obvious. When I remove these from the car to remove an engine I take the two ends off the valve covers and route them thru the engine compartment and then take the big hose clamp off at the TB and the lid and MAF off the air filter box as one big piece. Cant lose em this way and you can check for broken hose while you are at it. There are 2 that run from the valve covers up to that tubing, and one off the IAC valve. These are probably 10MM ID hoses so theyre pretty good size. They only fit one way without kinking them or something is why i say they are obvious. Link to comment Share on other sites More sharing options...
dolehendrix Posted December 4, 2005 Author Share Posted December 4, 2005 i looked at the alldata diagrams--- thise hose has two 90degree bends in it-- it runs from the intake manifold, right behind the coil, to the airfilter-throttle body pipe. could anyone get a part number for this hose for me? Link to comment Share on other sites More sharing options...
