measure your drive shaft
All the ea82 models except maybe XT/xt6 have the same wheelbase so you could use the 2 piece from them but you would have to add a center bearing mount. I just took my Brat driveshaft down to a shop and had them lengthen it.
Have a custom driveshaft made out of the original. Make sure it is balanced. The 2 piece ea82 mod is difficult because there is only very flimsy metal (the bed of the Brat) to hold to, and any twist or torque through the driveshaft will carry onto the weld on the bed - potential for bad juju.
Hey brat This is Jerry, just bring your old drive shalf to a drive line shop and tell them you want 51 inches of new tubing install in it and have it balance. Problem solved. For the brats and wagons the lenght is 51 inches and the hatchback is 48 inches of new tubing. Thanks Jerry
