wyosub Posted December 4, 2005 Share Posted December 4, 2005 I need to remove the cylinder block plug to install a block heater, anyone know what size hex wrench it takes? a lot bigger than anything in my metric box so I need to purchase or borrow the right size. TIA Willy 1992 Loyale, ea82, 1800cc, 5 speed. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted December 5, 2005 Share Posted December 5, 2005 It's 14mm. If you have an autozone, that's the only place I found that had allen sockets large enough. It came in a package of 3, 12, 14, and one larger one. Quote Link to comment Share on other sites More sharing options...
forester2002s Posted December 5, 2005 Share Posted December 5, 2005 14mm? That's not very big. You should be able to get that at Sears. EDIT: Whoops, I misread the OP. I thought that we were talking about a 14mm socket (which isn't that big). However a 14mm Allen Key is kinda large! Quote Link to comment Share on other sites More sharing options...
vic/se Posted December 5, 2005 Share Posted December 5, 2005 It's 14mm. If you have an autozone, that's the only place I found that had allen sockets large enough. It came in a package of 3, 12, 14, and one larger one. I did mine, I remove it with an allen wrench sorry I don't remember de size Quote Link to comment Share on other sites More sharing options...
sid_vicious Posted December 5, 2005 Share Posted December 5, 2005 I need to remove the cylinder block plug to install a block heater, anyone know what size hex wrench it takes? a lot bigger than anything in my metric box so I need to purchase or borrow the right size. TIA The only place I've found one of those separate from a set is online. There are usually a number of them on eBay. I think they're a common size for Mercedes-Benz oil drain plugs and other import plugs. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted December 6, 2005 Share Posted December 6, 2005 Autozone baby.....you get three sizes....for like 10 bucks. You can't beat that.....and I tried sears, home depot, lowes, etc. None of them had anything. Quote Link to comment Share on other sites More sharing options...
