Clutch Compatability for EA81 4SPD D/R
Can I run an XT6 clutch in my stock Brat transmission w/ an EA82 Flywheel? Will everything fit properly (using an EJ)?
Has anyone done this? I'm curious about people's experiences w/ the EA81 D/R trannys holding up to EJ's unbelievable power capabilities.
The input shaft of an EA81 D/R 4-speed is smaller then the input shaft for EA82/ER27 4wd transmission. You may have to use a clutch disk from EA82T 2wd Transmission but I'm not positive if that disk is compatible with a XT6 pressure plate.
I know that some people out there were talking about using EA81 4SPDs for their EJ swaps a while back.
I'm hoping to figure this out before it happens rather than during so that I can have the parts on-hand for the swap.
Can I use the stock EA81 flywheel on the EJ?
You can by all means use a stock EA81 flywheel and clutch setup on an EJ.
However, I doubt it will hold the power of the new EJ motor. Apparently Archimetis ran a stock EA81 flywheel/clutch/PP on his ER27 (XT6) powered hatch, and he had a lot of slippage going on.
His solution was to run an XT6 flywheel and PP with an EA81 clutch disc.
A custom Throwout bearing was needed to match both the EA81 input shaft and the XT6 PP. He used one from either a mid-80s or early 90s Nissan truck, he couldn't recall exactly which model, he just took the parts to NAPA and found one that worked.
When I get my hatch together I will be doing a clutch setup like this and I will make note of the exact components necessary for everyone's benefit.
  • Like 1
Great, that's just what I needed! I'm wondering how bad the clutch slipage is w/ the stock assembly as I would like to go that route as a temporary clutch and transmission setup to be followed by an EA82 tranny w/ good clutch.
As long as it's drivable, I can handle some clutch slip. :drunk:
