pkennedybluewrx Posted December 7, 2005 Share Posted December 7, 2005 i would like to take the side molding off of my 90 4wd wagon. are they glued? or are they screwed? has anyone done this before? Link to comment Share on other sites More sharing options...
critical_max Posted December 7, 2005 Share Posted December 7, 2005 The moldings clip on at several points per piece. You should be able to pry them off, though you'll probably want to fill the small holes in the body where the molding clips used to be. Link to comment Share on other sites More sharing options...
pkennedybluewrx Posted December 7, 2005 Author Share Posted December 7, 2005 Hey thanx for the info... Link to comment Share on other sites More sharing options...
Seahag1978 Posted December 7, 2005 Share Posted December 7, 2005 There's a little tool that looks like a two pronged fork. When you slide it behind the molding onto the clips, it pinches them together. They're usually pretty brittle, so it helps a lot to get them out without snapping them off inside or removing the inside door panel. Link to comment Share on other sites More sharing options...
