Rear end grinding noise fix
I am so stoked... my 88 GL wagon that I bought for WAY less that it was worth (needed a head gasket and "rear end work") is all done.... I did a total engine reseal and Jason (Baja) took a look at the rear end and all the noise in the rear (which I figured was a CV joint or the rear diff, or a wheel bearing acting up) turned out to be a loose axle nut :D
Way to earn your $100 Jason :banana:
So, Richie... I wont be needing that CV joint (thank god)
So the 88 is now spoken for... just needs a little interior tweaking (new power window switch) then it goes to a new home :-)
Down to 3 Subarus now.... I am having withdrawls already :rolleyes:
