xoomer Posted December 7, 2005 Share Posted December 7, 2005 Took my alternator out yesterday and took it to Autozone. And they tested it = good. I put it back in the car and its fine for about 70 miles... then starts acting up again... hmm? What could it be and does anyone have an alternator they might trade for soemthing I have because I be broke. Quote Link to comment Share on other sites More sharing options...
Snowman Posted December 7, 2005 Share Posted December 7, 2005 What exactly is the problem? If it's not charging properly, you could have a bad connection or a bad fusible link that's just barely passing current and gets worse when it warms up. I've also had a bad fusible link cause high voltmeter readings and all sorts of other wierd stuff. Bad grounds also can cause any number of problems. Quote Link to comment Share on other sites More sharing options...
xoomer Posted December 7, 2005 Author Share Posted December 7, 2005 well it started with dummy lights staying on until I rev up the motor... but then the lights will come on, from time to time.... and now I'm hearing a humming noise... So I'm thinking this suckers shot. Quote Link to comment Share on other sites More sharing options...
Bill90Loyale Posted December 7, 2005 Share Posted December 7, 2005 I've dumped way too much $ into replacing the diodes in the rectifier (twice) and a new stator (oem Hitachi alternator). I understand Bosch rebuilds are available online. Sorry I don't have a link. Quote Link to comment Share on other sites More sharing options...
toadleyb Posted December 7, 2005 Share Posted December 7, 2005 Here is a link for a Bosch Rebuilt. They are about 60.00 dollars. I put one in my car about a month ago and so far no problems. Got rid of the glowing indicator lights too. http://www.autopartswarehouse.com/alternators~pop.html Quote Link to comment Share on other sites More sharing options...
hatchsub Posted December 7, 2005 Share Posted December 7, 2005 One of the alternators that i had was overcharging bad but everytime i got it down to the shop to get it tested and verified that it was in fact the alternator it would act normal cause in the distance from my house to the shop it would warm up and everything would be good for awhile. grumble Ended up replacing it anyways and the problem went away. It could be the opposite of this i suppose. When you alternator is cool everything is ok but once its warm all hell breaks loose? That would be my guess. Quote Link to comment Share on other sites More sharing options...
xoomer Posted December 8, 2005 Author Share Posted December 8, 2005 fixed got an OEM alternator... for 25 at monster auto wrecking. Quote Link to comment Share on other sites More sharing options...
jacobs Posted December 8, 2005 Share Posted December 8, 2005 If you open up your old alternator I'm sure you'll find your brushes are worn out. I've purchased replacements at an auto electric garage in Denver for about $2.00/set. Quote Link to comment Share on other sites More sharing options...
ShawnW Posted December 9, 2005 Share Posted December 9, 2005 If you open up your old alternator I'm sure you'll find your brushes are worn out. I've purchased replacements at an auto electric garage in Denver for about $2.00/set. Which shop? Quote Link to comment Share on other sites More sharing options...
