Subaru sick :(
Have some questions on diagnosis...
Type of rig see below-->
Problem: when I accelerate the headlights and dash dim, volt meter drops, and temp gauge reads hot. ?? I let off the gas and all goes back to normal, Car isn't really "hot" just the gauge trips, seems there is a definite electrical drain when accelerating or putting the engine under load, which I guess with the "gutless wonder" is always under load!:)
Any theories on what is causing this to happen? I thought maybe a loose ground somewhere, couldn't find one,... I thought slipping belt...??? Can't tell though. I can't figure it out. Any thoughts and suggestions would be very helpful! Thanks
-Chris
You are right at idle, charges fine, guages normal. Alternator isn't that old but I will get it tested tomorrow after re-tightening the belt tension. Thanks for the help!
I will keep this updated on how it goes.
-Chris
it may be a weak altenator, or a bad/dying bettery.
ON my 1988 i had this weird problem which drove me nuts, almost the same thing, complete with a false high temp reading with the ac off. i decided to replace the raditaor (all the cooling fins were gone) the quite by accident i checked the elecrric cooling fan. It was tiff and hard to turn, so i replaced that and the problem went away. It seems the cooling fan was drawing too much current, and making the dash act odd.
I am not saying this is your problem, but if you have a heavy electrical load, like a calcified or shorted battery, it will show the same thing.
nipper
-Chris
YOu may have to get yourself a cheap ammeter gauge to see what is going on. An ameter gauge will tell you direction of current flow. How old are your battery cables?
Did this just start, or did it slowly start to occur?
i am assuming since the alt was tested, the battery was tested too.
On a really long shot, how are your motor mounts?
nipper
This problem just started this week when I drove to Seattle and back on Wednesday.
The cables for the battery are fairly new and in good condition. The engine mounts are worn and cracked slightly from stress when I put in the lift... Why?
I did find a larger wire that is grounded to the frame in the front right side next to the radiator and battery but the connector on the other end is broken. COuldn't find where this goes, any clues??? If it would help I could get a pic of the wire for reference.
I just went to Bend for the weekend and it drove fine on the way out, but on the way back started showing the same symptoms as described in the first post.
Thanks for all of the help, any suggestions are appreciated.
-Chris
that wire is a major ground to the body. It runs from the left head by the coolant pipe for the radiator to the body near the battery tray(radiator support).
when you are talking about positions in the engine compartment think of it as sitting in the drivers seat looking forward.
and yes that may be your problem.
-Chris
BINGO! thats broken cable is most likely your problem. I asked about the motormounts for a sneaky reason. To make you look under the car and inspect things. sometimes there are ground straps near the motormounts. Sometimes a broiken mountor mount can repeatedly flex a cable to damage it... sometimes i like to make people crawl under thier cars :drunk: (just kidding).
nipper
12484AUT_0180-med.JPGHere is the wire in my left hand and where it originally grounded to the frame. What is grounded by this wire? Where does it attach? Its an 8 gauge wire I think.
showphoto.php?photo=9289&size=big&sort=1&cat=500
Any thoughts on what this ground wire attaches to would be great because I can't seem to find where it goes.
http://www.ultimatesubaru.org/photos/data/500/12484AUT_0180-med.JPGHere is the wire in my left hand and where it originally grounded to the frame. What is grounded by this wire? Where does it attach? Its an 8 gauge wire I think.
http://www.ultimatesubaru.org/photos/showphoto.php?photo=9289&size=big&sort=1&cat=500
Don't mean to hijack the thread, just curious - what are the red cladded wire and the yellow cladded connector for on your neg. battery post? My loyale has neither. Thanks.
Anyone have any ideas?
I must have made my description a little vauge last time.:rolleyes:
heres a step by step.
1. remove your battery.
2. look at the left front of the motor. up on top.
3. there is a bracket for you coolant pipe from the waterpump.
4. on that pipe bracket there should be the other end of the ground wire.
5. go to parts store and crimp/solder a new end on the wire.
if your car is lifted you may need to just make a whole new ground as the motor does not sit in the stock location.
The wire with the yellow crimped end is the ground off of the alternator. The wires in the red wrap are for my aux lights.
Still no luck with the ground problem... Options not exhausted yet.
Thanks for the detailed description. I appreciate it, and know how hard it is to picture something then try to put it into words. So here I go: I checked the bracket on the coolent pipe and there is already a smaller gauge ground wire coming off of it and going into a black harness which then dissappears into the subframe behind the battery. I will pull off the alternator tomorrow to have a better look at the bracket and see if I am overlooking something. Thanks again for the helpful suggestions!
-Chris
  • 2 weeks later...
