Turbone Posted December 9, 2005 Share Posted December 9, 2005 Has anyone figured out how to wire trailer lights for EA82 wagons? I did a search, but everything that came up was for new gen rigs. I'm trying to save a little time, I know its going to be a PITA searching for the wiring harness in the back panels Link to comment Share on other sites More sharing options...
Will Smith Posted December 9, 2005 Share Posted December 9, 2005 I just pulled the panels off from behind the taillights and used an ohm meter to find the proper wires. You will need a 3 to 2 converter. The converters are marked as to the wiring. Link to comment Share on other sites More sharing options...
Numbchux Posted December 9, 2005 Share Posted December 9, 2005 You will need a 3 to 2 converter. The converters are marked as to the wiring. bingo! like this one: http://www.jcwhitney.com/autoparts/ItemBrowse/c-10101/s-10101/p-100000168701/mediaCode-ZX/appId-100000168701/Pr-p_CATENTRY_ID:100000168701 Link to comment Share on other sites More sharing options...
Tin Soldier Posted December 10, 2005 Share Posted December 10, 2005 *EDIT* Just realized the last post has a link in it to what you need so this whole message is now lame. (I will leave it tho since I am lame. ) Just in case you didn't understand the 3 to 2 convertor I will elaborate. Goto Walmart or any auto parts store. They are ruffly $20. It's an adapter for cars that have a seperate turn signal from the brake light. I don't have a part number on hand, but I have used 3 of them now. If you went to an auto parts store and told them what you need they would know. The adapter should come with a small LED test light so that you can figure out which wire is which. All of mine did anyhow. Just hook it up like they said right at your tail lights. The kit will tell which wires to hook to what. Probably takes about a half hour to wire it all up. Link to comment Share on other sites More sharing options...
Turbone Posted December 10, 2005 Author Share Posted December 10, 2005 So I need the adapter for each tail light?(I havent had my coffee yet) Link to comment Share on other sites More sharing options...
Qman Posted December 10, 2005 Share Posted December 10, 2005 So I need the adapter for each tail light?(I havent had my coffee yet) I've got the wiring adapter harness somewhere here. Link to comment Share on other sites More sharing options...
Numbchux Posted December 10, 2005 Share Posted December 10, 2005 So I need the adapter for each tail light?(I havent had my coffee yet) no, I think just one for the whole system.... Link to comment Share on other sites More sharing options...
Tin Soldier Posted December 10, 2005 Share Posted December 10, 2005 So I need the adapter for each tail light?(I havent had my coffee yet) No the kit has a box that has all the wires attached. you hook one wire to ground one to brake one for parking/headlights one to left turn signal then one long green wire to right turn signal that box will then have a regular flat four trailer connector for output Link to comment Share on other sites More sharing options...
Turbone Posted December 10, 2005 Author Share Posted December 10, 2005 I've got the wiring adapter harness somewhere here. I'll try and come by today. Link to comment Share on other sites More sharing options...
