TheSubaruJunkie Posted December 9, 2005 Share Posted December 9, 2005 Anyone know off the top of their head what the thread pitch for the water temp sending unit on our EA82's are? Im going to be replacing the gauges with new, mechanical gauges and Napa lists like 4 different units. Im not sure which one i need. -Brian Link to comment Share on other sites More sharing options...
fredrogers Posted December 9, 2005 Share Posted December 9, 2005 Well I recently put in a new mechanical temp sensor on my 87 gl wagon and the adaptor nut that goes into the block says: M16x1.5. Hope that helps! -=fred=- Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted December 9, 2005 Author Share Posted December 9, 2005 Yes it helps a bunch!! Thanks! -Brian Link to comment Share on other sites More sharing options...
Hondasucks Posted December 10, 2005 Share Posted December 10, 2005 I'm not 100% sure on this but those sending units SHOULD be pipe thread, the question is whether they are BPT or NPT (The fitting for the oil pressure gauge on my Datsun wsa 1/8 BPT which was almost but not quite 1/8 NPT..) Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted December 10, 2005 Author Share Posted December 10, 2005 The Napa listing for the parts im getting were NPT. Are subies NPT? -Brian Link to comment Share on other sites More sharing options...
MilesFox Posted December 10, 2005 Share Posted December 10, 2005 the napa and other generic temps gauges(mechanical) the threads will fit, you will have to use one of the fittings that come with it to secure the thermocouble to the diameter of the soob. keep any leftover pieces from gauge installs as they can be used like legos to adapt oil gauges, vice versa Link to comment Share on other sites More sharing options...
