kramresom Posted December 9, 2005 Share Posted December 9, 2005 I have a real bad exaust smell inside the car coming throught the vents. I took it to the dealer and they said i have no exaust leaks and don't know where it is coming from, but the smell is slowly giving me brain damage and i was wondering if anyone had the same problem?????? Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted December 9, 2005 Share Posted December 9, 2005 Put your car on a lift if you can and inspect the exhaust for holes or around the spots where donut gaskets are. Link to comment Share on other sites More sharing options...
beezer Posted December 9, 2005 Share Posted December 9, 2005 Brain damage.............yeah I got that. Could it be oil dripping onto the exhaust that you are smelling? Beezer Link to comment Share on other sites More sharing options...
friendly_jacek Posted December 9, 2005 Share Posted December 9, 2005 but the smell is slowly giving me brain damage and i was wondering if anyone had the same problem?????? You mean the brain damage part? But seriously, what smell are you talking about: sulfur? burning oil? unburn gas? You know, exhaust gases don't smell a lot in good running car. Link to comment Share on other sites More sharing options...
nipper Posted December 9, 2005 Share Posted December 9, 2005 hehe no thats antifreeze that can give you brain damage Your car is ripe for oil leaks. i bet you have either a P/S leak, of cam seals/main/oil pump leak. Valve covers i dont think leak onthe exhaust pipes the way the pipes are laid out. It only takes a tiny bit of oil to make a lot of smell nipper Link to comment Share on other sites More sharing options...
ShawnW Posted December 10, 2005 Share Posted December 10, 2005 MY money is on the power steering pump leaking. Link to comment Share on other sites More sharing options...
2.5 DOHC H gaskets suck Posted December 10, 2005 Share Posted December 10, 2005 I second checking the front and rear main seals for oil leakage they are notorius failures of your generation motor. If it is those you should see smoke coming from the engine bay after driving. I hate to be the one to say it but I have a horendous smell inside my 98 OBW and it is due to the head gaskets being shot. It doesn't smell like pure exhaust inside the car but it is the smel of something burning and it comes throught the vents. Link to comment Share on other sites More sharing options...
nipper Posted December 10, 2005 Share Posted December 10, 2005 i have a minor leak, and not sure what it is. Its either engine oil or antifreeze leak (I DONT WANT TO HEAR IT). It sometimes can be seen when the car is shut off with a puff of smoke. Oddly if i run the car long enough to burn it off the pipes, i dont have the problem again until the car is parked fro a while. Beofre i bought the car, the PS pump was replaced, and took a good month to burn that stuff all off. The engine had been resealed the year before, so im not sure what it is, it will have to wait till spring. In the meantime, recirculate is your freind, unless you use the defroster. heeh dont breath in the car in winter and youll be fine. nipper Link to comment Share on other sites More sharing options...
