211 Posted December 10, 2005 Share Posted December 10, 2005 Oh yeah! Resurfaced, Valve Grind, Cleaned and SHIPPED for $199.00, WITH a 1-year warranty Question: When I install the head bolts, should I coat the threads? Usually I use HighTack gasket sealant (GM applications). What would you recommend? Link to comment Share on other sites More sharing options...
Phizinza Posted December 10, 2005 Share Posted December 10, 2005 they look very clean Sorry, got no help for you just thought I'd say, good luck Link to comment Share on other sites More sharing options...
75subie Posted December 10, 2005 Share Posted December 10, 2005 Link to comment Share on other sites More sharing options...
Skip Posted December 10, 2005 Share Posted December 10, 2005 light machine oil I do this as I do not want metal to metal friction compromising the torque value Link to comment Share on other sites More sharing options...
pappy52 Posted December 10, 2005 Share Posted December 10, 2005 From wherest did the big brown van cometh? Link to comment Share on other sites More sharing options...
calebz Posted December 10, 2005 Share Posted December 10, 2005 Skip said: light machine oil I do this as I do not want metal to metal friction compromising the torque value +1 Also, if you are reusing head bolts, do yourself a favor and clean them with a wire wheel first. Link to comment Share on other sites More sharing options...
PeterD Posted December 10, 2005 Share Posted December 10, 2005 are thoes off of an ea81..? Link to comment Share on other sites More sharing options...
75subie Posted December 10, 2005 Share Posted December 10, 2005 ea82 i bet Link to comment Share on other sites More sharing options...
211 Posted December 10, 2005 Author Share Posted December 10, 2005 Yes, EA82. I got them from J&C Machine in W.Virginia. They do TONS of soob work. Machine oil huh? In that case won't regular motor oil work (obviously not glopped on). Link to comment Share on other sites More sharing options...
Subarian Posted December 10, 2005 Share Posted December 10, 2005 I use a light coat of motor oil. When you oil head bolts, you need to be careful, because it's really easy to overtorque. Link to comment Share on other sites More sharing options...
PeterD Posted December 10, 2005 Share Posted December 10, 2005 wow i gues i have never seen a bair ea82 head.. looks more like an ohv rather than an ohc. cool:) Link to comment Share on other sites More sharing options...
Subarian Posted December 10, 2005 Share Posted December 10, 2005 That's 'cause the cam towers aren't on them. There's not much that's prettier than clean, freshly machined metal. Link to comment Share on other sites More sharing options...
