phychotron Posted December 11, 2005 Share Posted December 11, 2005 82 gl wagon-- when i slide the heater to defrost, it only blows out a little bit, but more from the heat near my foot. Is there any sort of adjustment that i can make to get the flap to shut all the way? i was looking at it right now, and when i turn it to a/c the flap closes all the way, but as i slide it to heat, it opens, then only goes about halff way up when all the way on defrost... Link to comment Share on other sites More sharing options...
phychotron Posted December 11, 2005 Author Share Posted December 11, 2005 ok, the wierdest thing happend right now... i was looking at it, and i slid the control to max AC and i had a bit of pressure on it and i heard this kinda hiss for a second, kinda like air leaking out of something... and then i moved it back to defrost and the flap was a lot closer to bieng closed, maybe only 1/4" gap instead of about 3/4" gap... does this even make sense? Link to comment Share on other sites More sharing options...
nipper Posted December 11, 2005 Share Posted December 11, 2005 its vacum actuated. You have a vacum leak in the system. Its not weird... nipper Link to comment Share on other sites More sharing options...
phychotron Posted December 11, 2005 Author Share Posted December 11, 2005 its vacum actuated. You have a vacum leak in the system. Its not weird... nipper Dang it.... Link to comment Share on other sites More sharing options...
