Geoff4130 Posted December 12, 2005 Share Posted December 12, 2005 My OBW has a slushbox so I obviously can't push in the clutch when using the e-brake to do snow drifts, but should I put it in neutral? That is what I have been doing but I was wondering if I have to. Link to comment Share on other sites More sharing options...
NoahDL88 Posted December 12, 2005 Share Posted December 12, 2005 There is a solenoid that controls the AWD, and a fuse in the engine bay that disables it. under that theory, if you hook up a swith to the parking brake release button, you could have it activate when you push the button. I've got a 5mt that i'll be swapping in eventually so i just e-brake slide away, however, i put in a stiffer rear sway bar, so i don't need the ebrake for that any more. I have a OBS, so i used a WRX wagon bar, but in an OBW, you might need to get one from IDP or Rallitek Link to comment Share on other sites More sharing options...
charlierh2 Posted December 12, 2005 Share Posted December 12, 2005 Dont ebrake slide in a legacy. The only subaru that you can do that in is an sti because it disengages the rear wheels when you pull up in the ebrake. Link to comment Share on other sites More sharing options...
Geoff4130 Posted December 13, 2005 Author Share Posted December 13, 2005 Dont ebrake slide in a legacy. The only subaru that you can do that in is an sti because it disengages the rear wheels when you pull up in the ebrake. What if I put it in neutral first? Link to comment Share on other sites More sharing options...
syphon Posted December 13, 2005 Share Posted December 13, 2005 What if I put it in neutral first?I dont think that matters... as the front 2 wheels are still rolling and the rears aren't. Even though it's in "N", the Differential is still working (I think). It's the same reason you can't tow an AWD car on 2 wheels. Link to comment Share on other sites More sharing options...
Andyjo Posted December 13, 2005 Share Posted December 13, 2005 Like said above.. you can do it, but it's not good for your car.. i do it, i shouldn't.. but it's so much fun! Link to comment Share on other sites More sharing options...
Geoff4130 Posted December 13, 2005 Author Share Posted December 13, 2005 Thanks all! I only do it in the snow so I tell myself it's not as bad then, lol. I am having so much fun with all wheel snow drifts and we are supposed to get another 6" or so tomorrow, woo hoo!! Link to comment Share on other sites More sharing options...
