mountainbikeak Posted December 13, 2005 Share Posted December 13, 2005 I just replaced both front half shafts, most everything went ok, but now I can't get the pins in near the transmission. From what I understand the shaft can only go on one way and when Installing them I checked and made sure I aligned the valley of the spindle on the shaft to the ridge on the other end, seems just a bit off, enough where I can get about half of a drift through. Any help would be greatly appreciated need some wheels for work tomorrow. Thanks ahead of time. josh Link to comment Share on other sites More sharing options...
rallyruss Posted December 13, 2005 Share Posted December 13, 2005 probably off 180. pop it off and try it the other way. they usually have a taper on the CV and splined shaft where they line up. hard to explain but it sounds like you are off. Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted December 13, 2005 Share Posted December 13, 2005 If you look at the CV axle, the Trans. side. There will be a hole that has a taper to it. And the axle stub will have a hole that has a slight taper to it too, those two go together. If you notice, I think, the taperd hole on the stub is drilled through one spline, going through the center of it, as the non tapered hole is drilled between two splines Link to comment Share on other sites More sharing options...
NVBigBlue Posted December 13, 2005 Share Posted December 13, 2005 I agree with RalleyRuss..... Sounds like you are off by 180 degrees..... If everything is clean, you should be able to take a flashlight and look down through the roll pin holes. With the tapered side up, you should be able look right down the hole and see the top of the axle hole and the edge of the shaft hole. Sort of like this: (let me know if this doesn't look right...) \ / = Half shaft taper portion.... || = Shaft from tranny..... Otherwise it will look like: \ / | | (close...but not quite right...) If you relax and look at the parts both ways.... it will only look "right" one way. To me it's just one of those things that.....once you do right.... you'll know each time how it's supposed to go..... NV Link to comment Share on other sites More sharing options...
Subarian Posted December 13, 2005 Share Posted December 13, 2005 I agree. Turn it 180 degrees. Since it has an odd number of splines, the wrist pin can only go through if the splines are lined up right. If you have the pin out, you can stick a small screwdriver or drift through before you try to put the pin in to make sure it's lined up. Don't worry- you're almost there! Link to comment Share on other sites More sharing options...
northguy Posted December 13, 2005 Share Posted December 13, 2005 If you're having problems, either bring it to my house and we'll work on it there, or give me a call and I'll come lend a hand. PM me for my phone #. Link to comment Share on other sites More sharing options...
LUVMYBRAT Posted December 13, 2005 Share Posted December 13, 2005 Ditto on the 180, as I have experienced this exact problem. Get a pin punch or a screwdriver that fits the size, make it go all the way through before attempting to install roll pin. Link to comment Share on other sites More sharing options...
mountainbikeak Posted December 13, 2005 Author Share Posted December 13, 2005 Right on guys, thanks for the info... I thought Deep inside it might be that, dang. I'll check it out tonight and turn them/it 180. Thanks again josh Link to comment Share on other sites More sharing options...
markjs Posted December 13, 2005 Share Posted December 13, 2005 Actually I can say that mine were easy because they simply only line up one way, and if you get it wrong its cockeyed, (at least I am pretty sure it is), something about having an uneven number of splines or something like that. Link to comment Share on other sites More sharing options...
zyewdall Posted December 13, 2005 Share Posted December 13, 2005 Yup, I've put them on 180 degrees off, and the hole is only half lined up. Rotated it, and they lined up perfectly. Link to comment Share on other sites More sharing options...
