EA82Loyale Posted December 13, 2005 Share Posted December 13, 2005 Hey, I was just wondering, how hard would it be to carburate my engine? I have an EA82... Bill Quote Link to comment Share on other sites More sharing options...
zyewdall Posted December 13, 2005 Share Posted December 13, 2005 Hey,I was just wondering, how hard would it be to carburate my engine? I have an EA82... Bill What year, and what system does it have now? Why would you want to go from a fuel injected one to a carbureated system? Quote Link to comment Share on other sites More sharing options...
hatchsub Posted December 13, 2005 Share Posted December 13, 2005 Yeah i wonder this as well. Your much better off with fuel injection. Better gas milage and less drivablity issues. Quote Link to comment Share on other sites More sharing options...
EA82Loyale Posted December 13, 2005 Author Share Posted December 13, 2005 Hey,I was just wondering, how hard would it be to carburate my engine? I have an EA82... Bill Well, i was thinking of putting a weber on...its so gutless, but i don't want to do an EJ swap...i don't have the time (college full time) and i don't have the space... So it would only make things worse... Would EJ18 Cam shafts fit?? Is my engine a Dual or single?? Its an EA82 FI....Its a 93 from a Loyale, and its FWD auto... Thanks, Bill Quote Link to comment Share on other sites More sharing options...
Subarian Posted December 13, 2005 Share Posted December 13, 2005 I don't think it would be too hard. You would probably need to swap out the distributor for one from a carbed model, and the fuel pump on the injected model puts out more pressure, so if you didn't want to change that you would need a fuel pressure regulator, but the rest of it would just be fabricating any pieces you need to get the carb working, like the bellcrank and return spring. Quote Link to comment Share on other sites More sharing options...
zyewdall Posted December 13, 2005 Share Posted December 13, 2005 Its an EA82 FI....Its a 93 from a Loyale, and its FWD auto... Thanks, Bill That last word's the problem. Swap in a 5 speed and it should liven up a bit. Quote Link to comment Share on other sites More sharing options...
Subarian Posted December 13, 2005 Share Posted December 13, 2005 You'll pick up a little performance going from a stock carb to a Weber, but I can't say you would going from FI to a Weber. They're good carbs, but they're not magic. I agree with zyewdall, a manual trans would probably be a better upgrade. Your engine is a SOHC, and I don't know for sure, but I kind of doubt a cam from an EJ would fit. Quote Link to comment Share on other sites More sharing options...
EA82Loyale Posted December 13, 2005 Author Share Posted December 13, 2005 That last word's the problem. Swap in a 5 speed and it should liven up a bit. Already doing that...just bought another Loyale w/ a fivespeed for 300... bill Going in, in january! Quote Link to comment Share on other sites More sharing options...
Snowman Posted December 14, 2005 Share Posted December 14, 2005 Having run a stock carb, a weber carb, SPFI, and finally an EJ22 in my EA82 wagon, I would advise against "de-evolving". It might just have been that I'm not that good with carbs, but I had bad luck with mine, especially in cold weather. The SPFI system gives you about the same power as a weber, with better drivability and fuel economy. I know of more people that have converted their cars from carb to SPFI than the other way around, even though it's a lot more work to go from carb to SPFI, and I think there's a reason. Quote Link to comment Share on other sites More sharing options...
BoostedBalls Posted December 14, 2005 Share Posted December 14, 2005 If it's running at all with the injection- keep it. Just make sure the injectors are clean and the ecm isn't throwing any codes. The automatic is the problem. What is the purpose of the car? Is it your daily driver? Quote Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted December 14, 2005 Share Posted December 14, 2005 I agree, forget the carb. My modified (full exhaust, coil, and carb) carbed EA82 felt like it was just BARELY faster than a bone stock fuel injected model. With exhaust, an accel coil and a K&N filter (or cone air filter) should liven it up. A 5 speed will probably make the biggest difference though. Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted December 14, 2005 Share Posted December 14, 2005 I went from SPFI to a Webber, biggest waste of 500 bucks ever. if you already have SPFI, keep it, it will run better than even the best tuned weber, trust me. go through the basics, air filter, fuel filter, plugs, cap, wires, rotors. Be sure to use NGK's they will work best in that old EA-82, and on that note, no, EJ anything won't work, cams are totally different. Quote Link to comment Share on other sites More sharing options...
spanky_pete Posted December 14, 2005 Share Posted December 14, 2005 Are you in Centralia, Washington? I have a carbed ea82, and would be interested in your leftover fuel injection parts. Quote Link to comment Share on other sites More sharing options...
