rverdoold Posted December 14, 2005 Share Posted December 14, 2005 Hi folks my cel light in my 92 legacy 2wd 4at 213k KM (no mountains in holland to use awd although nex will be awd) goes off very quickly. It usually goes off after 1,5 2 seconds but now it goes off within 1 second. I have two errors in the computer 11 and 32 but they are there for a long time. is there anything wrong with the computer or system? Link to comment Share on other sites More sharing options...
sea#3 Posted December 15, 2005 Share Posted December 15, 2005 Code 11 - Crank angle sensor or circuit Code 32 - Oxygen sensor or circuit Try disconnecting the battery for and hour and that should get rid of the codes , drive it again and see if they return If they do i would suggest you replace them if the circuit is OK SEA#3 Link to comment Share on other sites More sharing options...
