December 15, 200520 yr just cleaned out the engine, and ran it for about 20 miles. sometimes at low rpms now one of the belts or sumtin starts squeeking...did i take the lube off something when i washed the engine..??
December 15, 200520 yr use a candle, even a votive candle will work, and hold it to the inside of the belt, obviously be very careful as this is safe if you pay attention, but can get dangerous if you are careless. the wax acts as a lube, but it won't make the belt slip. plane white boring candles are best, but i guess any candle would work.
December 15, 200520 yr just cleaned out the engine, and ran it for about 20 miles. sometimes at low rpms now one of the belts or sumtin starts squeeking...did i take the lube off something when i washed the engine..?? could be just an old belt that did not like the engine cleaner. either tighten the belt or replace it. nipper
