XT6 Clutch in EA81 4SPD (?)
The XT-6 Pressure plate will bolt on to the EA-82 flywheel (99%) sure.
When mateing the EJ to the EA-82, you use the redrilled EA flywheel, and the XT-6 flywheel and pressure plate.
Interesting to note, but the legacy has the same spline as the EA-82 transmissions. so you may be able to run a high po legacy kevlar clutch.
