sunil_meruga Posted December 18, 2005 Share Posted December 18, 2005 Hi, I own Subaru Outback 2001. Today when I started the engine it made a loud noice and since then it is making really loud noise after staring the engine. I'm not sure if it something related to exhaust pipe. Can some one tell me what could be the problem please? Thanks Sunil Link to comment Share on other sites More sharing options...
nipper Posted December 18, 2005 Share Posted December 18, 2005 could be a heat sheild, is it a tinny buzzy noise? nipper Link to comment Share on other sites More sharing options...
sunil_meruga Posted December 18, 2005 Author Share Posted December 18, 2005 could be a heat sheild, is it a tinny buzzy noise? nipper It is a coming from engine and like loud motor noice. Now the check engine light is also flashing. Link to comment Share on other sites More sharing options...
Gnuman Posted December 18, 2005 Share Posted December 18, 2005 Take it to the dealer. that sounds like a mechanical failure that will only get worse if not attended to quickly Link to comment Share on other sites More sharing options...
crazymjb Posted December 19, 2005 Share Posted December 19, 2005 There are a lot of things that can cause a loud noise. How long does it last after turning on the engine? At what RPM does it cut out? Is it constant or rythmic? Does it get louder or faster with acceleration? Can you open the hood and identify where it is coming from(please, don't poke at anything while its running unless you are very sure of what you are doing)? Link to comment Share on other sites More sharing options...
