95 super subbie Posted December 19, 2005 Share Posted December 19, 2005 i got this 91 loyale wagon auto for 50$ and only thing its good for is to demo it you cant have four drive so if i discoonect the rear drive shaft and take the rear out will it still move? do i have to leave it in front wheel drive or will it still go in four whell drive with the stuff taken out ? Link to comment Share on other sites More sharing options...
All_talk Posted December 19, 2005 Share Posted December 19, 2005 The automatic trans uses a clutch pack to transfer power to the rear (not a center diff), and will work fine without the rear drive. If its a 4EAT (did those even come in the Loyals ?) the TCU may throw a code. The 4WD switch just opens a soleinod that applies Vacuum to the 4WD servo (diaphragm) to apply pressure to the rear transfer clutch... just leave it in 2WD. Gary Link to comment Share on other sites More sharing options...
hooziewhatsit Posted December 19, 2005 Share Posted December 19, 2005 it's normally 2WD, and only goes to 4wd if you put it there. That said, if the rules require removing the driveline to ensure that you don't use 4WD, I would recommend taking out one or both rear axles instead. If you take out the driveline, you'll leak ATF, and the driveline needs the rear diff in place to hold it in place. Link to comment Share on other sites More sharing options...
NoahDL88 Posted December 19, 2005 Share Posted December 19, 2005 The rear driveshaft should be 2 piece. if it is, you can pull the center section of the drive shaft, behind the carrier bearing and in front of the rear diff, there will be a total of 8, 12mm bolts. be careful not to strip them, as after 14 years, it will happen easily. it should be clear very quickly if this is done right, if you see splines the wrong end was pulled. Link to comment Share on other sites More sharing options...
stephenw22 Posted December 19, 2005 Share Posted December 19, 2005 It's a 2-piece driveshaft, so you can take out just the back half of the driveshaft (the section with a u-joint at either end). Leave the front section in place, so the transmission fluid doesn't leak out. I had this done to my '85 wagon for about 2 years, after the rear axles went bad, and I couldn't find any replacement axles. Like it was said before, the subaru is normally a front-wheel drive vehicle. Pressing the 4wd button locks the rear wheels in. Not having the driveshaft in will make it front-only. Link to comment Share on other sites More sharing options...
NorthWet Posted December 19, 2005 Share Posted December 19, 2005 ... If its a 4EAT (did those even come in the Loyals ?)... The Turbo Loyales came with the 4EAT. 1990, maybe 1991 for Turbo Loyales? I am curious and a little confused (nothing new for me ) as to why you want to disable 4WD. Is this for some competition? Link to comment Share on other sites More sharing options...
95 super subbie Posted December 19, 2005 Author Share Posted December 19, 2005 The Turbo Loyales came with the 4EAT. 1990, maybe 1991 for Turbo Loyales? I am curious and a little confused (nothing new for me ) as to why you want to disable 4WD. Is this for some competition? its for a demolition derby that its going to next summer Link to comment Share on other sites More sharing options...
WoodsWagon Posted December 19, 2005 Share Posted December 19, 2005 Why not organize a new class for 4wd compacts. You could use tercels and subies and doge colt's. It would kick a lot more arse. It's retarded to reduce a car's ability just so you can fight sentra's and escorts. Link to comment Share on other sites More sharing options...
subie94 Posted December 19, 2005 Share Posted December 19, 2005 its for a demolition derby that its going to next summer imo,that's just like sending it to the scrap yard. unless the body is shot,then i'd be sneaky and use the 4wd. Link to comment Share on other sites More sharing options...
95 super subbie Posted December 20, 2005 Author Share Posted December 20, 2005 imo,that's just like sending it to the scrap yard. unless the body is shot,then i'd be sneaky and use the 4wd. yes the body is completly shot and i live in pa and we have year inspcetsion Link to comment Share on other sites More sharing options...
SakoTGrimes Posted December 21, 2005 Share Posted December 21, 2005 Well, you could convince the event organizers to just trust you not to push that little magic red button, so you wouldn't have to remove stuff (Demo cars should be heavier anyway, right?) Or you could scrape off all the 4WD decals and cheat, although someone with a good eye might see the rear wheels spinning. Link to comment Share on other sites More sharing options...
ausubaru92 Posted December 21, 2005 Share Posted December 21, 2005 Ive always wondered how a sube would go in a demo derby, our local show has a derby but the ground is usually wet and most cars get bogged, a subaru in disguise would be awesome:brow: P.S. try to disguise a piece of railway girder behind your bumper bars, the other cars wont know what hit them:lol: Link to comment Share on other sites More sharing options...
Buddy Posted December 21, 2005 Share Posted December 21, 2005 Ive always wondered how a sube would go in a demo derby, our local show has a derby but the ground is usually wet and most cars get bogged, a subaru in disguise would be awesome:brow: P.S. try to disguise a piece of railway girder behind your bumper bars, the other cars wont know what hit them:lol: are you crazy!!! no suby should be in a demo derby. take all the fords if you want but not the soobs. *sigh* i'd better go sit down before i hurt myself. oh wait i'm already sitting!!! Link to comment Share on other sites More sharing options...
waimaks Posted December 21, 2005 Share Posted December 21, 2005 I think its a great idea, if its already shot, go for it! I also have thought how cool a demo derby subie would be Link to comment Share on other sites More sharing options...
95 super subbie Posted December 21, 2005 Author Share Posted December 21, 2005 i will disconnect the four wheel drive first i don't cheat first year got a 5th out of 25 cars in the mini's this summer got a third,then i went in the feature kick butt i did not place but i had fun Link to comment Share on other sites More sharing options...
WoodsWagon Posted December 21, 2005 Share Posted December 21, 2005 We also want before and after pictures. Link to comment Share on other sites More sharing options...
95 super subbie Posted December 21, 2005 Author Share Posted December 21, 2005 We also want before and after pictures. the derby is next august and man this thing goes great in 6in snow in the field, aslo the farmer i bought it off from had a 86 Gl wagon which had a blown motor and was rusted beond rust which he said i could have it if i got it out of the field i got the rims off it before i called the junk to came with a rollback and get, and the good part i made money and had a car cant get better then that thier the 8 spoked white rims they look great with new paint Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted December 22, 2005 Share Posted December 22, 2005 Cut the button out for 4WD. They'll know your not using 4WD cause you'll be spinning out everywhere. If you want to have even MORE fun... then remove the front cvs joints and run with it in 4WD making it a true RWD car. Also, weld the rear diff before you do so you have RWD and POSI.... then KILLLLLLL ESCORTS!! -Brian Link to comment Share on other sites More sharing options...
95 super subbie Posted December 22, 2005 Author Share Posted December 22, 2005 Cut the button out for 4WD. They'll know your not using 4WD cause you'll be spinning out everywhere. If you want to have even MORE fun... then remove the front cvs joints and run with it in 4WD making it a true RWD car. Also, weld the rear diff before you do so you have RWD and POSI.... then KILLLLLLL ESCORTS!! -Brian but i think i leave it front wheel drive so i can use a backend of the car as much as i want so i can protect the frontend and the motor because any front wheel drive car can drag the backend all day long 91 super subbie station wagon 91 subaru legacy auto 2wd 95 subaru legacy 5spd awd Link to comment Share on other sites More sharing options...
subarubuddy Posted December 25, 2005 Share Posted December 25, 2005 but i think i leave it front wheel drive so i can use a backend of the car as much as i want so i can protect the frontend and the motor because any front wheel drive car can drag the backend all day long 91 super subbie station wagon 91 subaru legacy auto 2wd 95 subaru legacy 5spd awd you're right.. i've been to a lot of demo derbys and fwd cars ALWAYS do better because the steering and drive wheels are the same ones. so the rear end of the car can be totally destroyed and the front wheels will still drag the back of the car around and steer it somewhat even when the back wheels won't move anymore. also most of the derbys have a tech inspection before-hand...if the rules say 'no 4wd' they'll know if you have it before they even see the car move (they'll check). if you remove the rear axles or driveshaft like others were saying you'll be fine. if you run it as RWD only it hurts your chances because you have to protect the front and rear. FWD you only really have to be careful to protect the front. Link to comment Share on other sites More sharing options...
nkx Posted December 25, 2005 Share Posted December 25, 2005 Why not organize a new class for 4wd compacts. You could use tercels and subies and doge colt's. It would kick a lot more arse. It's retarded to reduce a car's ability just so you can fight sentra's and escorts. never gonna happen. there wouldnt be enough cars to make it competitive. at the demos around here theres usually only 1 or 2 heats of the compacts as opposed to 4 or 5 of the full size cars. Link to comment Share on other sites More sharing options...
95 super subbie Posted December 25, 2005 Author Share Posted December 25, 2005 never gonna happen. there wouldnt be enough cars to make it competitive. at the demos around here theres usually only 1 or 2 heats of the compacts as opposed to 4 or 5 of the full size cars. around here thier is as much compacts as big car entries, the derby is friday and satudaylast year their was 2 heats of minis about 20-25 cars and 4 heats of big cars about 12 in a heat Link to comment Share on other sites More sharing options...
Frank B Posted December 25, 2005 Share Posted December 25, 2005 If your going to be in the dirt/mud anyway, remove the front differential and weld the gears to have front posi ?! I also have removed the rear driveshaft and the car operates fine. Remove the rear differential, split the rear axle shafts and sell that stuff. Relocate the fuel pump, if your allowed. Since you'll be manuvering in reverse, the front wheel emergency brake will help you slide around and make tighter turns. Link to comment Share on other sites More sharing options...
95 super subbie Posted December 27, 2005 Author Share Posted December 27, 2005 If your going to be in the dirt/mud anyway, remove the front differential and weld the gears to have front posi ?! I also have removed the rear driveshaft and the car operates fine. Remove the rear differential, split the rear axle shafts and sell that stuff. Relocate the fuel pump, if your allowed. Since you'll be manuvering in reverse, the front wheel emergency brake will help you slide around and make tighter turns. weld the front differential?????? idont know what you are talking about and how do you do that Link to comment Share on other sites More sharing options...
WoodsWagon Posted December 28, 2005 Share Posted December 28, 2005 The differential is inside the transmision. It has small pinion gears inside it which let one wheel turn faster than the other on the same axel. It also lets you get stuck with one wheel spinning and the other doing nothing. If you weld the pinion gears together, it makes the front axel one piece so that both wheels have to spin to get stuck. Turning while going forwards gets harder. Link to comment Share on other sites More sharing options...
