Heater Console Sick...Goes Clickity Click
My heat/cooling console is clicking and draining small amounts of power from my engine when its engaged. i think it may not be grounded or just a bad heater unit. Anyone know what going on?
Just changed out the heater core in the 90 Legacy. Finally! Couldn't have done it with out you guys!
  Legacy777 said:
If it happens on every setting it's not the a/c. the a/c compressor only engages when on a/c, a/c max, and the two def settings.
Could it be a bad climate control console?
It still works fine, its just really annoying, but at least the heat works again.
It doesn't sound good for the engine either.
Does the clicking noise come from the engine compartment? Have you opened the hood with the AC running? If the compressor is making noise, there's really not much you can do. You could pull the wire at the compressor, and that will disable it though if you just don't want to deal with it.
