Gen 1 Auto trans question
Trans Part number 340258710
this is for the trany case...without the front diff...
covers years.
1977(stage1) and 1977(stage2), 1978
HT, 2d,4d sw(DL)
340253600 1975
HT GF, Coupe GL, 2dr DL, 4dr DL, SW DL,
no auto trany listed in my book for
1972, 1973(stage1) 1973(stage2) 1973(stage3) 1974
all the pix of auto tranys i could find for 75-79 they all looked the same. some part numbers were differnt. and may just be superceded.
anyway i hope this helps.
If I were a betting man (I am not :) ), I would say that if you had one it would probably be the JATCO unit, as it was used in the later cars. The M41 and M41A are probably near-twins (with each other); some relatively minor refinement. (BTW, the JATCO core was used in several other Japanese cars.)
Parts stores have asked me which 3AT I was buying a pan gasket for, as they are different shapes. This may be your best external distinguishing characteristic. If you take the pan off, the valve body should be marked with transmission ID.
I'm pretty sure the M series was from '74 - '77 stage I.It's shown in the '74 Auto Trans SM
Hope that helps.
If that tranny was the "A" then I'm guessing the M41 was the Japanese version.That looks like any stage I auto that I can recall,doesn't it?
