gsp4 Posted December 21, 2005 Share Posted December 21, 2005 I currenlty drive, 2004 OTB 2.5L, 4Cyl. 40,000KM with ORG All Season Tires 225/60R/16. My fried has offered me Slightly Used Snow Tires 225/55R/16. I was thinking of getting used Rims and putting these on. Dealer said, it’s not recommended; it’s not the safest thing to do. Can someone shed some light on this? Thanks, GSP Link to comment Share on other sites More sharing options...
benebob Posted December 21, 2005 Share Posted December 21, 2005 I currenlty drive, 2004 OTB 2.5L, 4Cyl. 40,000KM with ORG All Season Tires 225/60R/16. My fried has offered me Slightly Used Snow Tires 225/55R/16. I was thinking of getting used Rims and putting these on. Dealer said, it’s not recommended; it’s not the safest thing to do. Can someone shed some light on this? Thanks, GSP You'd be just fine but your odo would be off. Biggest problem I see is if the tires weren't rotated properly and don't have an acceptable small difference in circumference which is bad on an awd vehicle as the tires rotate at different speeds putting strain on the tranny. On the other hand those are some pretty wide snows. Depending on where you live and all narrower would be better so it sinks rather than floats across the top of the snow. That said if they have the same circumf. and are cheap enough start shopping for rims! Link to comment Share on other sites More sharing options...
gsp4 Posted December 23, 2005 Author Share Posted December 23, 2005 Thanks for the INFO. good day, gsp Link to comment Share on other sites More sharing options...
Ranger83 Posted December 23, 2005 Share Posted December 23, 2005 If you go to the manufacturer's website you can usally find the exact rolling diameter to see if there is a difference. Link to comment Share on other sites More sharing options...
