Hi,
First, let me say hello to everyone, as I'm new here.
I have a 98 Forester that I purchased new. Recently, I notice a noise from the rear right wheel (at least it sounds like that's where it originates). as I mentioned in the title, it's a grinding or whirring type noise. hard to describe.
I live in NYC, and only have 38000 miles on it, but they're tough miles on mean streets. Any thoughts? bearings? i gotta find a mechanic, but i'd like to go there with some idea of what the problem is. at least appear to know what I'm talking about.
I love my car, and this is the first problem i've had in 8 years.
thanks
steve
does sound like the tell tale bad rear bearing.
beefy Legacy replacement bearing is what you want.
To view pricing, or to order - go here:
1) https://www.subarugenuineparts.com/oe_parts_cat.html
2) look up by part numbers below
bearing - 28016AA030
oil seal - 28015AA090
oil seal - 28015AA100
oil seal - 28015AA110
axle nut (recommended) - 28044AA000
snap ring (recommended) - 28035AA040
let me know if you have questions.
this should get your whirring grinding noise sorted!
Jamie Thomas
Jamie at chaplins.com
http://www.subiegal.com
Oh yeah, you're most likely going to need a shop to change out the bearing, because you're "supposed" to use a hydrolic press to get them in and out.. pain in the rump roast if you ask me. I've had it done 3 times now (twice they didn't know about the legacy bearing), cost about.. $300 labor + parts, but if you get parts via Jamie it'll drive your cost down ;)
I am pretty sure the 98 Forester still used drum brakes in the rear. It is possible that the shoes are not fully retracting, for whatever reason, and rubbing against the drum.
I guess I would try and gently pull the parking brake up while driving to see if the noise changes, but make sure you keep your finger on the button so you don't engage the ratcheting mechanism. Can you "feel" anything when you do this? You could also stick your finger through the rim to touch the drum after driving...If one is really warm and the other isn't too bad, then that may help guide you in the right direction.
If it isn't your brakes, then it is the wheel bearing. 1998 Foresters love to chew them up and spit them out.
Take care,
Kevin
