WJM Posted December 22, 2005 Share Posted December 22, 2005 ...the rear unit is physically SMALLER. Both bearings are in difffrent locations. The rings will not interchange due to different bolt pattern (8 bolts rear, 12 bolts front). I am sure the stubs will not interchange. I am sure there are more items, however, i did not go beyond comparing the units side by side.... In order to make the rear unit work in the front, EXTREME machining modifications will need to take place. [TEASE]It would be alot cheaper and easier to............................[/TEASE] Link to comment Share on other sites More sharing options...
carfreak85 Posted December 22, 2005 Share Posted December 22, 2005 WJM said: ...the rear unit is physically SMALLER. [TEASE]It would be alot cheaper and easier to............................[/TEASE] Yes, go on... Link to comment Share on other sites More sharing options...
mcbrat Posted December 22, 2005 Share Posted December 22, 2005 WJM said: ...the rear unit is physically SMALLER. Both bearings are in difffrent locations. The rings will not interchange due to different bolt pattern (8 bolts rear, 12 bolts front). I am sure the stubs will not interchange. I am sure there are more items, however, i did not go beyond comparing the units side by side.... In order to make the rear unit work in the front, EXTREME machining modifications will need to take place. [TEASE]It would be alot cheaper and easier to............................[/TEASE] put the phantom grip in? Link to comment Share on other sites More sharing options...
WJM Posted December 22, 2005 Author Share Posted December 22, 2005 Phantomgrip=evil No PG for me. I will go quality with either a Kaaz or Cusco. Link to comment Share on other sites More sharing options...
Dr. RX Posted December 22, 2005 Share Posted December 22, 2005 WJM said: Phantomgrip=evil No PG for me. I will go quality with either a Kaaz or Cusco. Go with Cusco. Link to comment Share on other sites More sharing options...
WJM Posted December 22, 2005 Author Share Posted December 22, 2005 after researching...looks like I am going to go with a helical front. Better for tarmac. Clutch type for gravel. Link to comment Share on other sites More sharing options...
carfreak85 Posted January 15, 2006 Share Posted January 15, 2006 Ok, so what manufacturer makes an LSD for the front of an EA82 transmission? Link to comment Share on other sites More sharing options...
Caboobaroo Posted January 15, 2006 Share Posted January 15, 2006 carfreak85 said: Ok, so what manufacturer makes an LSD for the front of an EA82 transmission? Go find one for a Legacy or a '93-'01 Impreza and it should fit. Will did another article on how EA82 front diffs and EJxx front diffs are exactly the same right down to the part numbers. Link to comment Share on other sites More sharing options...
bratsrus1 Posted January 15, 2006 Share Posted January 15, 2006 Hi WJM This is Jerry, what is this cusco that you are talking about. I would like more info on this thing. Thanks Jerry Link to comment Share on other sites More sharing options...
Tycho Posted January 15, 2006 Share Posted January 15, 2006 Cusco and Kaaz manufacture aftermarket clutch type LSDs. Quaife, Torsen, and OBX (ugh) manufacture gear type ATB differentials. Everybody but torsen makes front diffs for the aforementioned EA/EJ cars. I'll say that gear type LSDs in a front drive application are heavenly. I have a Quafe in my front driver and the operation is completely transparent. You'd think it was an open diff till you put the hammer down at which point it immediately redistributes power appropriately. Link to comment Share on other sites More sharing options...
WJM Posted January 15, 2006 Author Share Posted January 15, 2006 Read this thread. Link to comment Share on other sites More sharing options...
