Check Engine Light?????????
Okay I posted about a week ago about my cel. Well Ive read about 10 different posts all with different answers. Some say plug the black some say pkug the green some say the led is on the ecu and some say its on the 02 monitor. Okay well I need the truth for sure. I have a 1988 gl-10 wagon. So I see the connectors and the ecu. What process do i go through to get my cel code. I see the green led in the back of the ecu but it flashes steady green flashes with the key on the on position. I dont get it. Someone let me know!!! Oh yeah I have also been to this website http://www.usmb.net/repair/?CurrentDirectory=FOLDER_3f29b58f4430b8.49200047/&FileType=Article&File=ARTICLE_3f2c055f4862e9.39782181.art
It doesn't really say where the flash is from. Thanks everyone!!!!
ecs = check engine
led on = rich led off = lean
red led = ea81 green led = ea82
for "U-CHECK" mode, do NOT connect connectors
for "D-CHECK" mode, connect GREEN connectors
if you are in "D-CHECK" mode, the ecs or check engine light will blink
you MUST be in "D-CHECK" mode to set timing
you Must be in "U-CHECK" mode to read present codes
