monstaru Posted December 23, 2005 Share Posted December 23, 2005 that is one big allen wrench.....i have already made one crankcase bolt tool.....it slips so went searching,only thiong i could find was a 5/8 allen.i am in the process of filing it down........crazy big Link to comment Share on other sites More sharing options...
bushbasher Posted December 23, 2005 Share Posted December 23, 2005 take a bolt with a head that fits in the hole, then tighten 2 nuts against each other on the threads of the bolt, use a wrench on the nuts. Thats my solution. Link to comment Share on other sites More sharing options...
rallyruss Posted December 23, 2005 Share Posted December 23, 2005 I assume you are talking about the 14mm allen used on the piston pin plugs and other case plugs? double nutting might not work on those. they usually take a lot of torque to remove. I went and got the right tool to pop mine out. Link to comment Share on other sites More sharing options...
Andyjo Posted December 23, 2005 Share Posted December 23, 2005 I went to the local shop and asked them if i could borrow the right tool for a day or 2, they didn't have a problem with it... because honestly, when do you ever use a 14mm allen tool! Link to comment Share on other sites More sharing options...
NorthWet Posted December 23, 2005 Share Posted December 23, 2005 Andyjo said: I went to the local shop and asked them if i could borrow the right tool for a day or 2, they didn't have a problem with it... because honestly, when do you ever use a 14mm allen tool! Well... I already had one in my toolbox. I think it fits headbolts on something... probably my Datsun. So, I guess they are not that uncommon. Link to comment Share on other sites More sharing options...
