Bypassing the WGDS ??
In my ongoing quest to cure the stumble in my 89 GL-10, I checkes the fault codes. 13, 32, and 44. Oxygen sensor, cam position sensor, and waste gate duty solenoid. I have a spare disty, and I just changed the O2 so I'll check the connection and for exhaust leaks. But could I bypass the WGDS? How is this tested?
My WGDS isn't even hooked up to get boost or vacuum. I have a vacuum line that runs from my turbo housing to the wastegate. There is a boost controller between them so I can run happily and quickly at 9 or so psi (damned fuel cut). None of the WGDS lines are hooked up, though it is plugged in to the wiring harness still.. No codes in the past year or so.
