mid-knight Posted December 24, 2005 Share Posted December 24, 2005 Do you guys know of it being done and what is envolved with it, both standard and AWD.Im considering it after redoing the motor in the wagon (GL10) and finding out there is piston slap to one of the cylinders, never heard the motor run i used the blovk from,and i cant seem to get the turbo boosted, nothin ive done works....new route needed, stress. Link to comment Share on other sites More sharing options...
Brumby Boy Posted December 24, 2005 Share Posted December 24, 2005 if you look in the retrofitting section you should be able to find all thge onfo you need Link to comment Share on other sites More sharing options...
NoahDL88 Posted December 24, 2005 Share Posted December 24, 2005 Searching is your friend. Yeah its been done, i've got 2 cars running that swap. Link to comment Share on other sites More sharing options...
NorthWet Posted December 24, 2005 Share Posted December 24, 2005 Do you guys know of it being done and what is envolved with it, both standard and AWD.Im considering it after redoing the motor in the wagon (GL10) and finding out there is piston slap to one of the cylinders, never heard the motor run i used the blovk from,and i cant seem to get the turbo boosted, nothin ive done works....new route needed, stress. Plenty of info if you search, but... What makes you think that you have "piston slap"? In 35 years of wrenching, I have NEVER run across a modern engine with true piston slap. (Sort of a pre-60's problem.) Likewise, boost is simple, as long as the pre-turbo exhaust doesn't leak badly, turbo is reasonably good, and the post-turbo exhaust isn't plugged. Not the info/advice that you are looking for, but: If you can't sort out your current problems without it stressing you, then you will pull all of your hair out trying to do an EJnn conversion. Relax and breathe for a moment. Link to comment Share on other sites More sharing options...
