Frank B Posted December 25, 2005 Share Posted December 25, 2005 Can the ring gear, or the whole differential assembly in the Sube trannies, and rear diff housings be flipped around to give you reverse rotation of the tires? I know it's done in VW trannies. Link to comment Share on other sites More sharing options...
WJM Posted December 25, 2005 Share Posted December 25, 2005 I dont think so. I know for a fact the rear diff cannot be swapped into the front. It is possible to have custom machined a reverse set of ring/pinion.... Link to comment Share on other sites More sharing options...
Subadoom Posted December 25, 2005 Share Posted December 25, 2005 I had thought of that so i took apart a 5 speed D/R. There is no way to flip the diff in the tranny that i could see. If some one dose I would like to know how. Link to comment Share on other sites More sharing options...
NoahDL88 Posted December 25, 2005 Share Posted December 25, 2005 What you might be able to do is to get the gear reduction hubs off of a Syncro, that would reverse the spin on the hub, so you wouldn't have to reverse the tranny output. it would definately be a custom one off application, but it might be worth looking into. Link to comment Share on other sites More sharing options...
All_talk Posted December 25, 2005 Share Posted December 25, 2005 Can not be flipped... look here for more: http://www.ultimatesubaru.org/forum/showthread.php?t=41009&highlight=flipped+hypoid+spiral Gary Link to comment Share on other sites More sharing options...
Frank B Posted December 26, 2005 Author Share Posted December 26, 2005 Coll, thanks. I was following this thread, http://www.ultimatesubaru.org/forum/showthread.php?t=49123 And thought it would be cool to have more gears in reverse! Link to comment Share on other sites More sharing options...
