N8NQU Posted December 25, 2005 Share Posted December 25, 2005 i will like to do away with the safety,i am, smart enough to put the E-brake on.my other 2 subs don't have it anyways.can somebody tell me how to bypass it??????thank you Bill. Merry X-mas to ALL. Link to comment Share on other sites More sharing options...
NorthWet Posted December 25, 2005 Share Posted December 25, 2005 You can't please everybody.... "No Clutch Lockout" thread: http://www.ultimatesubaru.org/forum/showthread.php?t=49127 Anyways, it should be a simple bypass. Perhaps the simplest (but not most elegant) would be to stick your head down by the pedals and find the switch that is on the clutch pedal mechanism. (I am working from general assumptions here, not specific knowledge.) Disconnect the connector from the switch and: 1) If the connector has only one wire (grounded by the switch), then run it to ground. 2) If it has 2 wires, jumper the wires together. It is possible that instead of jumpering that you need ot just leave the connector disconnected, but this is unlikely. Link to comment Share on other sites More sharing options...
N8NQU Posted December 25, 2005 Author Share Posted December 25, 2005 You can't please everybody.... "No Clutch Lockout" thread: http://www.ultimatesubaru.org/forum/showthread.php?t=49127 Anyways, it should be a simple bypass. Perhaps the simplest (but not most elegant would be to stick your head down by the pedals and find the switch that is on the clutch pedal mechanism. (I am working from general assumptions here, not specific knowledge.) Disconnect the connector from the switch and: 1) If the connector has only one wire (grounded by the switch), then run it to ground. 2) If it has 2 wires, jumper the wires together. It is possible that instead of jumpering that you need ot just leave the connector disconnected, but this is unlikely. thanks i'll check it out and see what i can do about it. Link to comment Share on other sites More sharing options...
