aks00b Posted January 1, 2006 Share Posted January 1, 2006 Hey everybody, new Subie guy here. Recently bought a brand new Outback and love it, all but the seatbelt beeper. The thing is pretty obnoxious, starts beeping just as soon as you start the car. Up here in alaska we occasionally start up and let warm up, so as soon as I get in I get the damn beeper, also sometimes if I'm just driving down to the corner store I don't necessarily feel the need to buckle up. Is there any easy way to turn the thing off? Quote Link to comment Share on other sites More sharing options...
brus brother Posted January 1, 2006 Share Posted January 1, 2006 Yep. Turn key to on position without starting car and then buckle and unbuckle the driver side seatbelt about 15 times quickly within a minute or less. Just do it as quickly as possible. Now turn the key to the off position and remove key. Next time and each time thereafter, the chime should sound 5 times and then stop. It worked first time for me but others had touble initially. If you have problems, use the search function on this site on the topic. Hey everybody, new Subie guy here. Recently bought a brand new Outback and love it, all but the seatbelt beeper. The thing is pretty obnoxious, starts beeping just as soon as you start the car.Up here in alaska we occasionally start up and let warm up, so as soon as I get in I get the damn beeper, also sometimes if I'm just driving down to the corner store I don't necessarily feel the need to buckle up. Good luck and welcome aboard. Is there any easy way to turn the thing off? Quote Link to comment Share on other sites More sharing options...
Smpol19 Posted January 1, 2006 Share Posted January 1, 2006 On my Impreza there was a little white box just above the drivers left knee under the dash board. It could be umpluged and it didn't affect anything else. What I did is i let the bell go on and went under the dash until i found it and then unpluged it. Quote Link to comment Share on other sites More sharing options...
aks00b Posted January 1, 2006 Author Share Posted January 1, 2006 Yep. Turn key to on position without starting car and then buckle and unbuckle the driver side seatbelt about 15 times quickly within a minute or less. Just do it as quickly as possible. Now turn the key to the off position and remove key. Next time and each time thereafter, the chime should sound 5 times and then stop. It worked first time for me but others had touble initially. If you have problems, use the search function on this site on the topic.I tried that once, it says do it 3 times really fast, I couldn't get it to work, but I think I had the motor running when I did it. I'll try again. Thanks. Quote Link to comment Share on other sites More sharing options...
frag Posted January 1, 2006 Share Posted January 1, 2006 On my Impreza there was a little white box just above the drivers left knee under the dash board. It could be umpluged and it didn't affect anything else. What I did is i let the bell go on and went under the dash until i found it and then unpluged it. Is'nt that the same beeper that warns the keys are still in the ignition? Quote Link to comment Share on other sites More sharing options...
aks00b Posted January 1, 2006 Author Share Posted January 1, 2006 OK, I found all the posts in the search, I'm off to try again..... Quote Link to comment Share on other sites More sharing options...
Tiny Clark Posted January 1, 2006 Share Posted January 1, 2006 There should be a plug under the driver's seat you can disconnect and jumper, though I'm not sure if it uses an open or a short to turn on the beeping. The wires will be coming from the seat belt lock. Driving at all without a belt is not too smart. Quote Link to comment Share on other sites More sharing options...
aks00b Posted January 1, 2006 Author Share Posted January 1, 2006 Ahhhh.....MUCH BETTER!!!! Quote Link to comment Share on other sites More sharing options...
mikem Posted January 1, 2006 Share Posted January 1, 2006 Ain't it great, my wife thinks I am just a genius for that piece of work. added hundreds to the resell value not to have to listen to that bit of noise. thanks to whomever discovered it. Quote Link to comment Share on other sites More sharing options...
aks00b Posted January 1, 2006 Author Share Posted January 1, 2006 Ain't it great, my wife thinks I am just a genius for that piece of work. added hundreds to the resell value not to have to listen to that bit of noise.thanks to whomever discovered it. Yep, it beeps 6 times and stops, now.I can handle 6 beeps. Quote Link to comment Share on other sites More sharing options...
brus brother Posted January 1, 2006 Share Posted January 1, 2006 The best part of the override is that if your passenger or even a heavy package was sitting in the passenger seat without the seatbelt buckled, you'd get the beeping even if the driver was buckled in. This way no more nagging. Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted January 2, 2006 Share Posted January 2, 2006 Just my two cents, But it seems to me that this "fix" will affect the proper airbag deployment, which can mean splat. of course if you are such a dumb@$$ to drive without your seatbelt i guess you deserve to go splat. sorry, that was .04 cents Quote Link to comment Share on other sites More sharing options...
mikem Posted January 2, 2006 Share Posted January 2, 2006 Just my two cents, But it seems to me that this "fix" will affect the proper airbag deployment, which can mean splat. seems like i have seen somewhere that is procedure is one that the dealer can perform for you, for a nominal fee. All that is changing is the number of beeps , not what is initiating the process. Nor is it bypassing the sensors measuring the "weight on seat" value. I certainly would not intentionally screw around with the system that was the sole reason for upgrading automobiles. If anyone has any info on NoahDL88's excellent thought I would sure like to hear about it. And thank you NoahDL88 for bringing that thought up here. Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted January 2, 2006 Share Posted January 2, 2006 And thank you NoahDL88 for bringing that thought up here. I used to work as an automotive restraints/airbag engineer, so i'm a little bit picky when it comes to seatbelts. the only thing worse than a broke subie, is a broken person in a subie that could have been avoided. Quote Link to comment Share on other sites More sharing options...
brus brother Posted January 2, 2006 Share Posted January 2, 2006 I didn't think the issue was whether to drive with or without a seatbelt. Personally, I'm not much for kissing a windshield. However, as I've said when the nagging beeping begins, "I heard you twice the first time". The original post "Up here in alaska we occasionally start up and let warm up, so as soon as I get in I get the damn beeper" caught my attention and I missed the part where he wanted to "drive to the corner store" unbelted, creating th potential to one day find himself lap dancing with a telephone pole. Correct me if I am wrong but I was lead to believe that the safety system remains intact but the warning ends after the 5 or 6 beeps once the reprogram described above is effected. Quote Link to comment Share on other sites More sharing options...
