rusty1 Posted January 3, 2006 Share Posted January 3, 2006 Got the code after buying Actron scanner to investigate cel. Cleared it and it came back immediately. Checked for 12v at connector for the vent control solenoid valve, no problem. Removed the solenoid valve/filter canister assemble and bench checked the solenoid valve by applying 12v from a battery charder to the connector terminals, At first chattery then seemed to be working right, but when returned to vehicle cel back on after clearing. Wondering if I should go ahead and replace the valve anyway or if i bench tested it correctly or if i have the right part to be checking for that code. TIA. Link to comment Share on other sites More sharing options...
ferret Posted January 3, 2006 Share Posted January 3, 2006 P0446 means the ECU hasn't detected the 12v coming back thru the Drain Valve Solenoid before it activates (grounds) it. This is at pin a10 of the ECU. If you checked the correct valve/solenoid, then I would suspect either a poor connection at one of the conectors or a damaged wire. You can start at the solenoid connector itself and either work your way to the Main relay(if 12v is missing) or back to the ECU (if the 12v was present at the solenoid return side). The Manual calls P0446 Vent Valve low.....the attached diagram calls it the Drain Valve Link to comment Share on other sites More sharing options...
rusty1 Posted January 3, 2006 Author Share Posted January 3, 2006 Thanks for the diagram, the part number I'm working with is 42084FA120. Just to be sure, does this agree with your info? Link to comment Share on other sites More sharing options...
rusty1 Posted January 6, 2006 Author Share Posted January 6, 2006 Thanks again, Ferret. BTW , where did you get the diagram? Looks like something online. Link to comment Share on other sites More sharing options...
ferret Posted January 6, 2006 Share Posted January 6, 2006 I have a few vehicles on CD. Link to comment Share on other sites More sharing options...
dakos Posted October 16, 2009 Share Posted October 16, 2009 hi, i'm getting same issues but i can't locate the canister and solenoid...i just got the 2000 forester which is a little bit different as engine components locations than my 99 forester...any help will be more than appreciated, pictures or a diagram. thanks a lot! Link to comment Share on other sites More sharing options...
dakos Posted December 12, 2010 Share Posted December 12, 2010 hi, could the P0446 generate a missfire on all 4 cylinders ? as the weather got cold the car runs really bad and the missfire codes for all 4 cylinders came up beside the p0466 code. the whole summer and fall the car was running fine even the code was there but now since the temperatures are dropping below - C the car runs bad... thanks a lot. Link to comment Share on other sites More sharing options...
c3mercury Posted May 21, 2017 Share Posted May 21, 2017 have same trouble with a 2000 forester p0446 replaced valves both work have 12-v @ plug tested wire to pin 10@ecm also good still have code any ideas???? is driver in ecm bad ??any help would be good here Link to comment Share on other sites More sharing options...
