subeman90 Posted January 3, 2006 Share Posted January 3, 2006 Borrowed from Ultimate Subaru Message Board 3.8.00 posted by Zapar If the hole the post is in gets stripped, it isn't a big deal to fix it. At your local auto parts store, you should be able to find what's called a 'Helicoil thread repair kit'. The kit should contain; 1 drill bit, 1 Tap (re-threads), several helicoils, and a helicoil installer. The kit is kind of self-explanatory, but basically you drill the existing hole to clean it out, rethread the hole with the tap, and screw in a helicoil. The hole will be stronger than when it came out of the factory. The size that should fit (EA-81 models) is M-10 by 1.25. M-10 meaning 10 mm. The whole process should take less than a half hour, including taking off the Y-pipe. The Sub mechanic who first told me about it said to be smart and use a post again rather than a bolt. (In case you need to take that damn pipe off again) Should quiet that noise right down. Update:07/24/2001 I recently performed this operation on my 86 HB. I found it to fairly easy but will say this. Drilling into your heads can play games on you mentally. Don't give yourself an ulcer worrying about it and have some faith in your tools and handywork. My HB is QUITE a bit quieter than it ever was before. ANother thing to remember is that it will need at least 2 inserts per hole, and I encountered a couple of inserts that just didnt want to cooperate with the insertion too. The kit was around $60 from Napa. I found this was the only place in town that had the correct bolt and thread kit. Basically take your time, dont make it a 30 minute job the first time, and tell us about your success when you are through. Link to comment Share on other sites More sharing options...
moosens Posted January 3, 2006 Share Posted January 3, 2006 I would like to add that Timeserts are excellent for the person who expects to take their Y-pipe down at least one more time or more in the future. The Timesert is a cylinder threaded on both the inner and outer sides so you can always take your bolt out and re-insert it without the coil coming out with it.Timeserts go in the same way a heli coil does and lock into a chamfer.Pricey but worth it to some folks. Link to comment Share on other sites More sharing options...
Phizinza Posted January 6, 2006 Share Posted January 6, 2006 If you are going to do this. Use real "helicoil" style inserts (they look like a spring.) I used cheap rip offs that were like a thred with a threded hole in it. They just pulled right out after a couple of weeks. I am now getting the heads fixed again, after I took it too a pro repair guy and his welds have broken. So. Use expencive stuff. Also, remeber to NEVER drill further then the original hole. (like I did ) you will have oil flowing down the stud and all over the rocker cover, crossmember, driveshaft, and exhaust. Link to comment Share on other sites More sharing options...
