subeman90 Posted January 3, 2006 Share Posted January 3, 2006 Oil Leaking Into Coolant This can be easily seen by opening your radiator, and seeing if oil is ontop of the radiator fluid, or if your coolant is a very dark color (if it has been running and has gotten mixed pretty well) What cuases this? 90% of the time, in a Subaru, its a cracked head. Rarely does the actual gasket go out, they just crack =( ( for those who arent into cars, a 'cracked head' is seriouse, should be taken to a repair shop imeidatly, a new one runs almost 400 US Dollars. Rebuilt ones are cheaper, and less reliable. If you plan to do all this yourself, give yourself a 3 month window for a full overhual on the engine, unless you REALLY know what your doing! ) Submitted by: Morgan Mains Link to comment Share on other sites More sharing options...
