Troubleshooting A/C Problems
subeman90
Symptoms: Pure clean water dripping into passenger side floor from under dash. Water is condensing onto the underside of the dash area on passenger side.
Problem: A/C drain hose may be plugged up.
Solution: Find short rubber drain hose coming out of the firewall inside the engine compartment on the passenger side. Run a wire coat hanger (or similar device) up into the drain tube to free blockage. Be sure to rotate hanger around good to totally clear tube, so blockage does not re-appear quickly.
