Nonfunctional Heater Fan Speeds
subeman90
Non functional heater fan speeds are normally caused by a burned open resistor block. This block is mounted in the duct work ( for cooling purposes as the device does get quite hot.) This duct is behind the glove box and can be accessed from below after removing the plastic panel. The block will have four or five wires going to it. Submitted by Holigans Likeus
