Guest Hondasucks Posted July 28, 2003 Share Posted July 28, 2003 Ok what years were the Turbo axles bigger than the non-turbo, and was it only on the manual trannies, or was it on the automatics as well? Link to comment Share on other sites More sharing options...
Guest GlCraigGT Posted July 28, 2003 Share Posted July 28, 2003 I'm 99.9% sure that turbo axles were bigger then the other axles for all years of ea82. Both manual and automatic got them. if you are trying to tell ea82 axles apart look at the shaft on the CV end. You should see what looks like a bump where shaft diameter gets a little bigger then back to normal. If there is 1 bump it's a 2wd axle, 2 bumps for 4wd and 3 bumps for turbo. Note this only aplies to OEM axles, with aftermarket axles; you never know. Link to comment Share on other sites More sharing options...
Guest Hondasucks Posted July 28, 2003 Share Posted July 28, 2003 I looked the parts up on The Parts Bin, and it showed a part number for 1986 Automatic Turbo 4WD axles, but it said "call for availability" for 1986 Manual Turbo 4WD front axles. Link to comment Share on other sites More sharing options...
Guest GlCraigGT Posted July 28, 2003 Share Posted July 28, 2003 you might want to call a dealer in the morning and confirm. At the subaru shop i worked at, when we sorted used axles in our parts warehouse, we only did it by 2wd, 4wd and turbo. it didn't matter what transmission they came off of nor did it matter when we put them on cars. Link to comment Share on other sites More sharing options...
Guest Hondasucks Posted July 28, 2003 Share Posted July 28, 2003 dangit.. IF that is the case, do you kow if the axle stubs are interchangeable? I know the rear ones unbolt... Link to comment Share on other sites More sharing options...
Guest GlCraigGT Posted July 28, 2003 Share Posted July 28, 2003 I can't remember. It's been 6 years since i worked there. The only thing i remember about the stub axles is that they are held in using a snap ring Link to comment Share on other sites More sharing options...
