Hi folks. Hey I heard somewhere that those rubber cargo trays found in Outbacks will also fit into the older '90-'94 Legacy wagons. Is that correct and if so, which years of Outbacks had trays that would fit my 94? Thanks!
Ok vinyl, rubber, whatever. The sliding around problem I can cure easy enough with some rubber backed carpet.
I guess if nobody has an answer I'll just have to go to Aaron's Auto Wrecking and see for myself if the early Outback trays fit the '90-'94s.
Let's see mine measures about:
42in. from front to back
22in, down from the front, is where it fans out
top part is 41in. accross
bottom part is 52in. accross
Comes in pretty hand, don't have to worry about spills. But things do slide around a bit!
--Nick
Mike, and everyone else,
yes, they fit. Not to a tee but they fit good enough to not have a problem with it. Mine got "treated" and is quite slippery. I installed a cargo net also to keep the little things from flying around. Check it out next time you're down Mike.
