skeates Posted January 4, 2006 Share Posted January 4, 2006 What should I expect for maintenance on a 06 OBW 2.5 non-turbo, manual tranny. Cost and lifespan woudl be appreciated In particular: Clutch life Front and Rear brake Life Center diff (Viscous coupler) and rear diff (limited slip) and is Heat gaskets an issue on these vehicles Thanks Link to comment Share on other sites More sharing options...
Legacy777 Posted January 5, 2006 Share Posted January 5, 2006 A lot depends on how you drive, but clutch should last at LEAST 75-100k. Front brake pads, at least 20k....probably way more....rear pads....probably double what the fronts do. Center diff, no maintenance. Rear diff....just change the fluid every 60k or so. I don't think the headgaskets are an issue any more. Link to comment Share on other sites More sharing options...
skeates Posted January 5, 2006 Author Share Posted January 5, 2006 Assuming best case, normal wear and tear. Link to comment Share on other sites More sharing options...
