lhrocker Posted January 5, 2006 Share Posted January 5, 2006 The low beam on my 95 Legacy wagon doesn't seem to be working but the hi beam is fine. I swapped the bulbs already with new ones and old ones that work, but I get the same results. Is there a way to test the connection? This wouldn't be a fuse issue, right? Thanx, Pete Link to comment Share on other sites More sharing options...
Tiny Clark Posted January 5, 2006 Share Posted January 5, 2006 The fuses supply voltage to both bright and dim lights. The lamps are turned on by a ground being supplied to them thru the combination switch. At least, that's what is shown in diagram I have. If you have daytime runnng lights, then it's a bit different. Link to comment Share on other sites More sharing options...
