tailgatewagon Posted January 6, 2006 Share Posted January 6, 2006 Ok guys i was thinking it would be cool to have all the normal part numbers so that we can look for them on ebay, subaruparts.com and others so ill start the page and fill in the oem partnumbers as people name parts(i have an ea81 parts book) just need to know what parts are important,, Overhaul Gasket Kit 497123011 Intake Gasket 322115100 carb base gasket 322050100 head gasket exhaust gasket rear crank oring 413967100 front oil seal 38x59x9 806738070 water pump 410767300 water pump gasket 417407000 oil pump oil pump oring 806914020 14x2.4 oil pump gasket 424207000 oil pump rebuild seals 806949030(49.7x3.5)and 806915050(15x1.5) oil filter 420337110 oil pan gasket 411607000 oil drain plug gasket 311680100 oil pick tube oring 806914020 (14x2.4) thermostat gasket 817554110 thermostat 417537000 valve cover gasket 412607000 valve cover bolt gasket 812764110 crank Shaft Woodruffkey 053205300 crank case plug gasket Pass side front 803936020 (36.2x44x1.5) crank case plug gasket(under water pump) 803926020 (26.2x31.5x1.5) motor mounts trany mounts exhaust gaskets exhaust studs and nuts accsesory belts 1 Link to comment Share on other sites More sharing options...
moosens Posted January 6, 2006 Share Posted January 6, 2006 motor mounts tranny mounts oil pump gaskets,seals (for pump rebuild and install) exhaust studs and nuts accesory belts valve cover gaskets Link to comment Share on other sites More sharing options...
