Russ Hill Posted January 7, 2006 Share Posted January 7, 2006 Where is it? I have no power to the pump, I'm guessing the fuse but it isn't marked on the panel. Link to comment Share on other sites More sharing options...
gbrand Posted January 8, 2006 Share Posted January 8, 2006 Do you have power during start? If it powers during start but not run then there is a problem with your charging system-the fuel pump in "run" is powered via the external voltage regulator(but charging system must be working)-in start mode it is bypassed. This drove me nuts when the brushes in the alternator became so worn they were intermittent, car would stall out as charging sytems failed, then restart OK. Long story I have posted before. Finaaly put jumper wire to batt to get me home. Check it out and let me know if you need details. Let us know Link to comment Share on other sites More sharing options...
Cougar Posted January 9, 2006 Share Posted January 9, 2006 Check the fusible links for a loose connection. Link to comment Share on other sites More sharing options...
rubuild Posted January 9, 2006 Share Posted January 9, 2006 Where is it?I have no power to the pump, I'm guessing the fuse but it isn't marked on the panel. It's either above the fuse box in a single fuse holder probably still wrapped in tape, or the behind the right kick panelKerry/Roo-Builders Link to comment Share on other sites More sharing options...
