MSSLGECKO Posted January 9, 2006 Share Posted January 9, 2006 So, as we know you are to have your wheels straight when putting a sube in 4WD - why? Do they need to be straight when going between 4Hi and 4Lo? Thanks, Link to comment Share on other sites More sharing options...
stngllhm Posted January 9, 2006 Share Posted January 9, 2006 the reason to have your wheels straight when shifting from 2wd to 4wd is so that the wheel speed are all close to the same. so when you engage the rear end there won't be any grinding. when shifting from 4 hi to 4 lo since you already have the rear end engaged it is not important to have them straight. Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted January 9, 2006 Share Posted January 9, 2006 But its never a bad idea to have them straight anyways And its probably not a good idea to shift from high to low if you're peeling out. -Brian Link to comment Share on other sites More sharing options...
Subaru Jim Maple Ridge Posted January 9, 2006 Share Posted January 9, 2006 Wheels can be turned, it doesn't matter. All you are doing is engaging the splitter gear in the front of the tranny, the front and rear tires are already connected. Link to comment Share on other sites More sharing options...
mudduck Posted January 9, 2006 Share Posted January 9, 2006 I have never woyyied about having the wheels striaght Link to comment Share on other sites More sharing options...
scrap487 Posted January 9, 2006 Share Posted January 9, 2006 mine will engage sometimes when they arent straight, but I cant be moving, but it wont come out of 4wd if the wheels are turned or if there is any kind of bind. Link to comment Share on other sites More sharing options...
jeffast Posted January 9, 2006 Share Posted January 9, 2006 i strongly reccomend not going hi to lo on the fly it is horrable for the tranny Link to comment Share on other sites More sharing options...
Caboobaroo Posted January 9, 2006 Share Posted January 9, 2006 i strongly reccomend not going hi to lo on the fly it is horrable for the tranny well maybe if you're in a turn but on dry pavement, shifting from High to Low is perfectly fine that I know of. Done it lots of times and never had any issues... Link to comment Share on other sites More sharing options...
Numbchux Posted January 9, 2006 Share Posted January 9, 2006 well maybe if you're in a turn but on dry pavement, shifting from High to Low is perfectly fine that I know of. Done it lots of times and never had any issues... yep, just make sure you push in the clutch, it's just like changing any of the other gears Link to comment Share on other sites More sharing options...
ballitch Posted January 9, 2006 Share Posted January 9, 2006 if you have issues with getting out of 4WD you should go in reverse and back up a car length or so to unload the bind in the tranny. i put it into 4WD on wet roads, ice, snow, and gravel. i heard someone say "dont engage 4WD unless there is at LEAST a 10-20% slippage factor on the surface your driving on. seems to work for me. i also go into 4 LO while on the fly, i dont jam it in there, i give it time ( a second or two) to engage and then i let the clutch out slowly. ~Josh~ Link to comment Share on other sites More sharing options...
Syonyk Posted January 9, 2006 Share Posted January 9, 2006 My trick for getting out of 4WD if it's a bit bound up is just to hit the brakes hard enough to cause some slip. It frees things right up. I see no problems with shifting between 4Lo & 4Hi on the fly - as said above, it's just like shifting between other gears. The front & rear stay locked, and an additional reduction gets dropped in. I don't *usually* shift between 4Hi & 4Lo on the fly though, because I use 4Lo for "Ah, crap, I guess I *am* stuck." -=Russ=- Link to comment Share on other sites More sharing options...
torxxx Posted January 9, 2006 Share Posted January 9, 2006 I Shift on the fly up and down from hi to lo. You just gotta be easy on it and match the gear speed. If you are gonna shift to 4lo from 4hi 1st gear you need to be in 3rd gear before you put it in 4lo to match up the gear speeds to your tire speeds. Shifting from 4lo to 4hi works just fine, just hold the clutch down and it'll shift right out of lo to hi Link to comment Share on other sites More sharing options...
SuBrat84 Posted January 9, 2006 Share Posted January 9, 2006 I just wont shift into 4Lo if I'm 35mph+... anything slower than that you just gotta make sure you know what gear to be in when switching from Hi to Lo. Link to comment Share on other sites More sharing options...
Hank Roberts Posted January 10, 2006 Share Posted January 10, 2006 Torxxx: > shift to 4lo from 4hi 1st gear you need to be in 3rd gear > before you put it in 4lo to match up the gear speeds to your tire speeds. How? You're in high range 4wd in first gear. Going how fast? Do you -- put in the clutch -- move the gearshift to third -- move the transmission to low range -- let in the clutch ?? I dunno, I've always been crawling just above stall uphill in high first gear and just shifted into low range and given it a little gas as I let the clutch up, ending up in first gear in low range. But I've wondered. Link to comment Share on other sites More sharing options...
MSSLGECKO Posted January 10, 2006 Author Share Posted January 10, 2006 I personally use 4Lo like it's another gear. I don't sweat changing gears while changing between the ranges most of the time. The only thing that I do worry about is rev-matching and that's the same as shifting any into any other gear. I've put my Brat into some great slides in low traction roads by downshifting into Lo using 2nd gear and it works flawlessly. Owning EA D/R's has made me dislike driving trucks and other non on the fly 4WD's more because of the lack of versatility for city and highway driving. As far as the MPH that I'll go in 4-Hi or -Lo, it is limited by the gearing, the occasional speed limit sign, and my engine power. When I ran the D/R in RWD, I had no problem using 4Lo on the highway for hills and on-ramp accelerations and am not worried about the Lo range standing up to high speeds, I think its fine to do 65+ in Lo if you can get your car that fast on safe roadways. Link to comment Share on other sites More sharing options...
SuBrat84 Posted January 10, 2006 Share Posted January 10, 2006 I think its fine to do 65+ in Lo if you can get your car that fast on safe roadways. If your vehicle is in good shape this is no problem.. especially in a 5spd DR. Just don't be trying to go from 4hi to 4lo at 65mph Link to comment Share on other sites More sharing options...
