never before seen TOD cause (and solution)
I'd never seen it before.
Substituting the wrong o ring + too much cam case sealant = ... (click the pic to see more pics)
Pulled that criznap out, cleaned things up, cranked it ... poof ... (enjoy the) silence.
seen an XT6 owner do this. tried reusing the cam carrier o-ring (the bottom corner one) with excessive sealant. it sucked up the sealant and caused same issues.
anaerobic sealant all the way, this wouldn't have happened.
i also took apart an ER27 tha ti picked up from someone and they installed a regular oring instead of the metal ring reinforced oring, glad i caught that ahead of time!
Cam journals, lobes, the rocker pads, and the lifters themselves all looked fine. Low spring pressures + wide lobes / large journals was the saving grace there I'd say. These engines really are over engineered in many ways.
As a note...there was no sealant sucked up. That's ALL o ring.
